STP Root Guard Cause STP Topology Change ?
phucle001
Hi Anyone,
Can anyone please advise if implementing Root Guard on the Root Bridge will cause a STP Topology Change, thus effectively causing a LAN outage because STP reconvergence is required?
I need to know this fact so I can decide to implement Root Guard during Business Hours or After Hours.
Thank you
Phuc
petenixon
Level 3
Level 3
It all depends on your topology and where you apply root guard. I think as long as you're only applying root guard to designated ports you will be ok.
If you apply root guard to a root port, where you would expect BPDUs, the port will stop forwarding.
Root bridge:
All (designated) ports configured for root guard.
STP switches:
All non-root (designated) ports configured for root guard.
