Warning message
ASA 9.1 Trouble with tunnel-group-list enable
Answered Question
Jul 17th, 2014
Hello!
I'm trying to get a configuration working where Cisco VPN / DTLS phones can VPN connect, while still allowing remote access via AnyConnect clients to PCs.  I have two tunnel-groups and group-policies configured for this purpose, and am using group-urls.
Phones are connecting fine, but I do not get the pull-down menu to choose between the two tunnel-groups when connecting from a remote computer.
Below is an excerpt from the config.
By the way, I did have the menu working previously when I was using group aliases instead of group-urls.  However, the phones seem to require the group-urls.  Now that I have those configured, the menu doesn't work.  If I enter the complete URL in the AnyConnect window, both of the URLs work, and I can log in.
Thank you in advance for any suggestions you might have!
Deb
webvpn
 enable OUTSIDE
 anyconnect image disk0:/anyconnect-win-2.5.2014-k9.pkg 1
 anyconnect image disk0:/anyconnect-macosx-i386-2.5.2014-k9.pkg 2
 anyconnect image disk0:/anyconnect-linux-2.5.2014-k9.pkg 3
 anyconnect enable
group-policy ABC internal
group-policy ABC attributes
 wins-server value 10.10.16.17 10.10.16.12
 dns-server value 10.10.16.17 10.10.16.12
 vpn-simultaneous-logins 3
 vpn-tunnel-protocol l2tp-ipsec ssl-client ssl-clientless
 split-tunnel-policy tunnelall
 default-domain value abc.com
 address-pools value AnyConnectPool
 webvpn
  anyconnect ssl dtls enable
  anyconnect keep-installer installed
  anyconnect ssl rekey time 1440
  anyconnect ssl rekey method ssl
  anyconnect dpd-interval client 5
  anyconnect dpd-interval gateway 30
  anyconnect ask none
group-policy ABC-STG internal
group-policy ABC-STG attributes
 dns-server value 8.8.8.8
 split-tunnel-policy tunnelspecified
 split-tunnel-network-list value Split-Tunnel-Encrypt-ACL
 webvpn
  anyconnect ask none
tunnel-group Split-Tunnel-Group type remote-access
tunnel-group Split-Tunnel-Group general-attributes
 address-pool AnyConnectPool
 default-group-policy ABC-STG
tunnel-group Split-Tunnel-Group webvpn-attributes
 group-url https://asa.abc.com/ABC-STG enable
tunnel-group ABC-Tunnel-Group type remote-access
tunnel-group ABC-Tunnel-Group general-attributes
 authentication-server-group ACTIVE-DIRECTORY
 password-management
tunnel-group ABC-Tunnel-Group webvpn-attributes
 group-url https://asa.abc.com/ABC enable
Correct Answer by Dinesh Moudgil about 3 years 1 month ago
Hi ,
You can have group-alias and group-url simultaneously  in the configuration so that phones can connnect with group-url and users can click on drop down menu to select the right connection profile.
tunnel-group <tunnel-group-name> webvpn-attributes
group-alias <tunnel-group-alias> enable
group-url <url> enable
Ref:- http://www.cisco.com/c/en/us/support/docs/security/asa-5500-x-series-next-generation-firewalls/98580-enable-group-dropdown.html
Dinesh Moudgil
P.S. Please rate helpful posts.
Overall Rating: 5 (1 ratings)
Correct Answer
Dinesh Moudgil Fri, 07/18/2014 - 00:12
  • Cisco Employee,
Hi ,
Dinesh Moudgil
ciscotac16 Fri, 07/18/2014 - 11:39
Hi, Dinesh.
Thanks for your reply.
I did previously try the configuration that you suggest, but it did not work either.  I had the menu working, but as soon as I added the URL for the phones, the menu wouldn't display.
I will go back and reconfigure it and try again just in case I fat-fingered something before.  I'll post the results here.
Deb
ciscotac16 Fri, 07/18/2014 - 12:16
OK!  So, maybe I did fat-finger something yesterday....or maybe the ASA just needed to sleep on it.... :^)
At any rate, the menu is working again now, *and* the phones can still connect.
I must have had this same config in there at least 3 times while I was working on it yesterday (tried all sorts of things)....< Sigh >
Thanks again,
Deb
Dinesh Moudgil Fri, 07/18/2014 - 12:17
  • Cisco Employee,
Hi Deb,
I am glad it is working.
Dinesh Moudgil
pemasirid Thu, 08/21/2014 - 02:14
Hi Dinesh,
I want to disable group-alias (or disable tunnel-group-list) for webvpn (clientless) users but enable for AnyConnect Client users. I disabled tunnel-group-list under webvpn (global) but this disables for both clientless as well as AnyConnect client VPN.
We dont want to show all the available groups for webvpn users who access via https.
Is there a way we can disable group-alias only for webvpn (clientless) users..?
thanks...
Dinesh Moudgil Thu, 08/21/2014 - 05:21
  • Cisco Employee,
This setting gets applied to all the SSL users . whether client based or clientless VPN.
You can either disable the webvpn page (using keepout command) for all the users or completely disable the group-alias.
Dinesh Moudgil
pemasirid Sat, 08/23/2014 - 23:08
Hi Dinesh,
Thanks for your reply. Actually we dont want to completely disable group-alias and we need ONLY to disable for webvpn (SSL) users and keep it for AnyConnect users.
We dont want to show all the available groups for webvpn users who access via https and it should able to show only SSL (clientless) vpn group when they access via https and show all available AnyConnect groups list for AnyConnect users (using IPsec) who access via AnyConnect clients.
Appreciate if you can let us know whether this is possible with SSL vpn.
Thanks and regards,
