SSL VPN on a Cisco Router - AnyConnect config: How to Limit Concurrent logins
LJ Gabrillo
Level 5
Level 5
Hi everyone,
Pretty much what the title says.
I wan to limit concurrent logins.
Currently, one username can be used by many to login, but I dont want it that way.
Is it possible to set that once the username is used and currently connected. It cannot be used to login. Much like the 'max-logins' in the old reliable VPN Client
Is there a way to limit it in SSL-VPN(AnyConnect)
INFO ON MY CONFIG:
1. Using local username/password
    -will pretty soon link my AD as my AAA Server
6 Replies 6
Marcin Latosiewicz
there is an internal enhancement request open for this. AFAIU it's not fulfilled - CSCuj25736.
Also please be aware that LDAP is not supported method for AAA in webvpn on IOS, or at least it was until recently.
edit: re last one:
Unsupported features:
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/sec_conn_sslvpn/configuration/15-mt/sec-conn-sslvpn-15-mt-book/sec-conn-sslvpn-ssl-vpn.html#GUID-E83B5B7E-8905-4261-9145-51640F12DED9
Lightweight Directory Access Protocol (LDAP) Support
Hey Marcin,
Just tested it out in our network -- itegrating our LDAP Server and it works :)
Just created an ldap server config in router, add it to a group and apply it to the aaa authentication list
The notes are not saying it will not work, but it's still not supported, unless that note was removed from a newer release (which I have not seen).
You maybe able to get it to work, but it's most likely something which is not tested internally.
Thanks Marcin! :D
Thanks for the Heads up Marcin,
Ill try to confirm if AD can be used in AAA
might as well try it in my lab as well :D
Am using Cisco RV345 routre and i have configured SSL VPN. Can I restrict concurrent user login ?
Srikanth
