SG200-50P fan problem (not operational)
damian.woz
We have problem with 2 FAN’s on our Cisco SG200-50P 50-Port Gigabit PoE Smart Switch (FW version: 1.3.5.58, Boot version: 1.0.0.1).
On View Log -> Flash Memory we have a lot of logs like this below:
2147445310
2014-Jul-19 12:26:29
Alert
%Environment-A-FAN-STAT-CHNG: FAN# 3 status changed - not operational., aggregated (1)
2147445447
2014-Jul-19 12:25:33
Alert
2147445600
2014-Jul-19 06:18:08
Alert
%Environment-A-FAN-STAT-CHNG: FAN# 4 status changed - not operational., aggregated (1)
2147445753
2014-Jul-19 06:16:58
Alert
%Environment-A-FAN-STAT-CHNG: FAN# 4 status changed - not operational., aggregated (6)
2147445906
2014-Jul-19 06:14:44
Alert
2147446043
2014-Jul-19 06:14:21
Alert
2147446196
2014-Jul-19 02:58:13
Alert
We have checked, that switch FAN’s are fully operational (they are blowing air). System LED is blinking amber all time.
chrebert
Level 4
Level 4
Hello Damian,
One thing I do notice is that your boot code has not been updated to match your firmware.  The firmware itself is also one version behind, so I would upgrade that as well.
1.3.7.18 firmware and bootcode is available here:   SG200-50P Downloads
In order to upgrade the firmware you will need some sort of TFTP software.
Hope that helps,
Christopher Ebert - Advanced Network Support Engineer
Cisco Small Business Support Center
*please rate helpful posts*
