Warning message
How do I access the web utility with model cisco sf302-08p ?
Endorsed Question
Jul 21st, 2014
Hi,i have a problem with the model Cisco SB SF302-08PP Switch , i connect a cable rj45 to my pc and configure the adapter local area connection (ip address:192.168.1.252), the LEDs blink green, and go to the address bar and get the IP by default, which according to the manual is 192.168.1.254 and the result is: page not found. Is there any way to change the web utility? How do I access the web utility?
Cisco Endorsed by Pratheep Kumar K
nijamudeen_aziz about 2 years 10 months ago
restore  the switch by holding more than 30 seconds and try accessing with ip 192.168.1.254. username and password is "cisco". before change your base ip to 192.168.1.2-253.try to ping and check the connectivity
Overall Rating: 5 (1 ratings)
Pratheep Kumar K Sat, 09/13/2014 - 11:27
Take a paper clip,hold the reset button for 30 seconds then try to access the web interface. It will work.
nijamudeen_aziz Tue, 09/30/2014 - 23:32
