07-22-2014 08:13 PM - edited 03-01-2019 02:47 PM
Dear All,
Today I faced a strange problem and I want to share it with you to find what is the problem ?
we have a VRF for one customer and we use interface vlan to define customer's branch.
The customer interface is VLAN 422 and it is defined under customer VRF probably .
PE#sh running-config vrf V3056:RIYADHBANK
Building configuration...
Current configuration : 1321 bytes
ip vrf V3056:RIYADHBANK
rd 65000:3887
maximum routes 1400 80
route-target export 65000:5405
route-target import 65000:5405
route-target import 65000:5406
interface Vlan422
description By *****
ip vrf forwarding V3056:RIYADHBANK
ip address 172.29.12.97 255.255.255.252
service-policy input 2M_IN
PE#sh vlan id 422
VLAN Name Status Ports
422 422 active Gi3/0/11 efp_id 422
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
422 enet 100422 1500 - - - - - 0 0
Remote SPAN VLAN
Disabled
Primary Secondary Type Ports
PE#
we can see the interface vlan is up
PE-L3Agg-Khu-107-2#sh int vlan 422 description
Interface Status Protocol Description
Vl422 up up ****
PE#
and we can see the vlan 422 belongs to the correct VRF
PE#sh vrf V3056:RIYADHBANK
Name Default RD Protocols Interfaces
V3056:RIYADHBANK 65000:3887 ipv4 Vl627
Vl775
Vl422
PE#
when we tried to troubleshoot the customer routing we found :
PE-L3Agg-Khu-107-2#ping vrf V3056:RIYADHBANK 172.29.12.97
Sending 5, 100-byte ICMP Echos to 172.29.12.97, timeout is 2 seconds:
Success rate is 0 percent (0/5)
PE-#
we could not ping the ip address of interface vlan 422.
PE#sh ip route vrf V3056:RIYADHBANK 172.29.12.97
Routing Table: V3056:RIYADHBANK
% Subnet not in table
PE#
PE#show ip route vrf V3056:RIYADHBANK connected
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
+ - replicated route, % - next hop override
Gateway of last resort is 192.168.111.16 to network 0.0.0.0
172.29.0.0/16 is variably subnetted, 338 subnets, 2 masks
C 172.29.12.44/30 is directly connected, Vlan627
L 172.29.12.45/32 is directly connected, Vlan627
PE-L3Agg-Khu-107-2#
PE-L3Agg-Khu-107-2#
My question is: Why the interface vlan 422 is not installed in VRF Table as it is UP ??
thanks in advance!
Rashed Wardi.
07-23-2014 06:09 PM
what platform is this? can you please paste the output of show version and show run?
Also when you tested this was int Gi3/0/11 up/up?
Best Regards,
Bheem
09-24-2014 01:31 AM
WE GOT IT,
THE PROBLEM WAS THE LIMIT UNDER VRF
