Warning message
Subscriber innstalation CUCM 10
Answered Question
Jul 24th, 2014
I have upgrede the CUCM from 9 to 10.
I have publisher CUCM 10.X version.
I would like to innstal the subscriber, but I have only CUM 9.1 bootable image.
Is it possieble to install sub 9.1 when publisher is 10 or the subsriber version must be the same like publisher ?
Thanks in advance
Correct Answer by Jonathan Schulenberg about 3 years 3 weeks ago
This begs the question: how did you get the CUCM 10 publisher installed if you lack a bootable ISO? If this is a BE6k you may want to browse the ESXi datastores as it likely exists on one of them. If a Cisco partner did the install on your behalf, ask them to supply these to you. You would need them for disaster recovery purposes anyway.
If for some reason none of that is possible, just submit a PUT order to go from 9.x to 10.x and it will issue you a bootable ISO download link. If you lack a ESW/UCSS contract - which would be mighty confusing since this sounds like a very recent deployment - then your only option would be to speak with your Cisco AM/SE. None of us can legally supply you with this directly.
Correct Answer by Jaime Valencia about 3 years 3 weeks ago
That only works with patches, not with major upgrades, 9 to 10 is a RU because of the OS change
Overall Rating: 5 (4 ratings)
Suresh Hudda Thu, 07/24/2014 - 09:44
  • Gold, 750 points or more
  • Cisco Designated VIP,
    2017 IP Telephony
No, we can't.
Suresh
George Thomas Thu, 07/24/2014 - 10:25
  • Blue, 1500 points or more
You could try to install patch during the version 9.x install and go to 10.x
Correct Answer
Jaime Valencia Thu, 07/24/2014 - 12:19
  • Cisco Employee,
  • Hall of Fame,
    2011
macieknowak Thu, 08/21/2014 - 04:34
Thanks a lot for support.
You have right the patches option dosen't work with major upgrade.
Correct Answer
Jonathan Schulenberg Sat, 07/26/2014 - 15:28
    2017 IP Telephony
macieknowak Thu, 08/21/2014 - 04:36
Thank a lot.
I get the ISO bootable from our Cisco's Suport.
Related Content
