We have integrated LDAP server we are not able to authenticate via LDAP for network authentication
ccietrainee1
please help
Hi CCIE Trainee,
I suggest that you use a packet analyzer (wireshark) to evaluate step by step the reason for failure.
Usually this is associated with permissions in LDAP.
What system are you trying to integrate with LDAP?
Luciane de Medeiros
Hi There :D
Can you verify the ports on your AD. Make sure ports are allowed
***LDAP Ports
389/TCP
389/UDP
or better yet disable the firewall xD
Also, what device are you using that is using LDAP to add, what feature? :)
