Warning message
catos -> nativeos conversion
Jul 27th, 2014
I have to conversion from catos to nativeos.
I will use tool if it can configuration automatically conversion.
I'm lookking for a configuration conversion tool and using guide.
Rajeev Sharma Sun, 07/27/2014 - 23:23
  • Silver, 250 points or more
Hey,
Regarding your concern for conversion you may start here:
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-6500-series-...
Moreover you may use the configuration conversion tool but i am not sure if it will convert all the commands, you may have to check the configuration guide for rest of the commands:
HTH.
RS.
