Warning message
FTP ERROR ASA CISCO
Jul 28th, 2014
Hi Am getting below error while am try to copy image from ftp server.
aaaaaa# copy flash:flash:/asa821-k8.bin ftp
Source filename [/flash:/asa821-k8.bin]? asa821-k8.bin
Address or name of remote host []? xxxxxx
Destination filename [asa821-k8.bin]?
Writing file ftp://xxxxxx/asa821-k8.bin...
%Error writing ftp://1xxxxxx/asa821-k8.bin ()
Overall Rating: 2.7 (3 ratings)
nkarthikeyan Mon, 07/28/2014 - 04:29
  • Gold, 750 points or more
Hi Vasanth,
Try like this...
ASA#copy flash: ftp:
Source filename []? asa821-kb.bin
Make sure that you are able to ping the FTP server from ASA and FTP Server to ASA.... if needed you may need to allow the ACL to do with the FTP transfer......
enable ftp in asa
conf t# ftp mode passive to make asa to respond for ftp traffic.....
also look at the logs in ftp server app
Karthik
vasanthmanoharan Mon, 07/28/2014 - 04:36
Hi Karthik am able to ping the server and also i have enabled passive mode but one thing the server is Linux machine ...
But still am getting same respond
nkarthikeyan Mon, 07/28/2014 - 04:53
Hi Vasanth,
When you initiate ftp from ASA, do you see any hit count in FTP Server application logs or something?
As an alternate option you can try with tftp to do with.... similar commands you can use...
Karthik
vasanthmanoharan Mon, 07/28/2014 - 05:04
thats am surprising am not getting any logs in firewall the connectivity as follows there is one management switch connected with with firewall same switch connected with server also.
and is there is no option for tftp in linux i hope only we can do ssh that setup is in my remote location .
nkarthikeyan Mon, 07/28/2014 - 05:37
Hi Vasanth,
I believe we can do tftp in linux.... can you check on that?
to which IP you are trying to do ftp on asa? is it an inside IP? can you allow udp any any on outbound acl and check if you see any hits.....
also do you have inspect ftp enabled in asa service policy???
Karthik
vasanthmanoharan Tue, 07/29/2014 - 07:37
Hi I got solution there is some thing mis configured with FTP server post rectified i am able to transfer the files.
