Warning message
Configure port forwarding for both 500 and 4500 on ASA 5550
Answered Question
Aug 1st, 2014
Hello I am trying to open up port forwarding for both 500 and 4500 as below but if i try to add tcp 4500 the 500 is removed; is there any way both can be added. sorry am new to firewalls and would be grateful to have some insight on it please?
object network obj-VPN(1:1)
 nat (inside,outside) static xxx.xxx.xxx.xxx service tcp 500 500
Many Thanks
Correct Answer by nkarthikeyan about 3 years 2 weeks ago
Hi Kaushik,
All you need is to use two different object's to achieve it..you cannot bind that in a single object with 2 NAT rules.....
object network obj-VPN-500
host xxx.xxx.xxx.xxx
object network obj-VPN-4500
 nat (inside,outside) static xxx.xxx.xxx.xxx service tcp 4500 4500
Karthik
Overall Rating: 5 (2 ratings)
Correct Answer
nkarthikeyan Fri, 08/01/2014 - 03:48
  • Gold, 750 points or more
Hi Kaushik,
Karthik
Kaushik Ray Fri, 08/01/2014 - 03:55
Thanks Karthik for your reply.
 nat (inside,outside) static AAA.AAA.AAA.AAA
i have the above set at the moment; so do i have to create two separate NATs with two Public IPs?
or can use the two objects to NAT to the same public IP?
Jouni Forss Fri, 08/01/2014 - 04:05
You will be using the same public IP address in both if you configure Static PAT (Port Forward)
So you create an "object" for both Static PAT configurations and you will use the same public IP address in both but forward a separate port in each Static PAT configurations.
Karthik provided the Static PAT configurations format above.
If you were configuring Static NAT (which you arent) you would need separate public IP addresses.
- Jouni
nkarthikeyan Fri, 08/01/2014 - 04:04
Hi Kaushik,
Both the options you can do... either with the single IP or with different IP's... I hope by looking at your earlier configuration it seems that you were trying to do with single/same IP...
Karthik
