Warning message
VOIP Monitor is OUT OF SERVICE on UCCX - 9.0.2 - 9.0.2.11001-24
Aug 1st, 2014
Hi All - Recently implemented UCCX 9.0.2  in HAOLAN setup, Where VOIP MONITOR is OUT OF SERVICE on Subscriber Node.
Restarted cluster - No go
Any idea ?
1492016: Jul 24 14:53:10.175 GST %MIVR-SS_VOIPMON_SRV-3-VOIP_OPERATION_ERROR:VOIP subsystem operation error: Module Name=LrmVoipManager.recovery,A specific description for a trace=fail to read OPEN_CONF msg returned is null,Exception=
1492017: Jul 24 14:53:10.773 GST %MIVR-CFG_MGR-7-UNK:BSSession:heartbeat::BSSocket.nextInvokeId=130945
1492018: Jul 24 14:53:10.774 GST %MIVR-CFG_MGR-7-UNK:BSMessageWriter-1.writeMessage-> about to write bootstrap message = HEARTBEAT_REQ[length=-1,invokeId=130945]
1492019: Jul 24 14:53:10.814 GST %MIVR-CFG_MGR-7-UNK:BSMessageReader-1.run-> message read: HEARTBEAT_CONF[length=4,invokeId=130945]
1492020: Jul 24 14:53:15.777 GST %MIVR-CFG_MGR-7-UNK:BSSession:heartbeat::BSSocket.nextInvokeId=130946
1492021: Jul 24 14:53:15.777 GST %MIVR-CFG_MGR-7-UNK:BSMessageWriter-1.writeMessage-> about to write bootstrap message = HEARTBEAT_REQ[length=-1,invokeId=130946]
1492022: Jul 24 14:53:15.818 GST %MIVR-CFG_MGR-7-UNK:BSMessageReader-1.run-> message read: HEARTBEAT_CONF[length=4,invokeId=130946]
1492023: Jul 24 14:53:20.195 GST %MIVR-SS_VOIPMON_SRV-3-VOIP_OPERATION_ERROR:VOIP subsystem operation error: Module Name=LRMConnection.readMSG: lrmHost: 172.17.16.10 , lrmPort: 3000,A specific description for a trace= error is: ,Exception=java.io.EOFException
1492024: Jul 24 14:53:20.195 GST %MIVR-SS_VOIPMON_SRV-3-EXCEPTION:java.io.EOFException
1492025: Jul 24 14:53:20.195 GST %MIVR-SS_VOIPMON_SRV-3-EXCEPTION:    at java.io.DataInputStream.readInt(DataInputStream.java:375)
1492026: Jul 24 14:53:20.195 GST %MIVR-SS_VOIPMON_SRV-3-EXCEPTION:    at com.spanlink.lrm.io.CRSLRMInputStream.readINT(CRSLRMInputStream.java:211)
1492027: Jul 24 14:53:20.195 GST %MIVR-SS_VOIPMON_SRV-3-EXCEPTION:    at com.spanlink.lrm.io.CRSLRMInputStream.readMHDR(CRSLRMInputStream.java:356)
1492028: Jul 24 14:53:20.195 GST %MIVR-SS_VOIPMON_SRV-3-EXCEPTION:    at com.spanlink.VOIPMonitor.subsystem.LRMConnection.readMSG(LRMConnection.java:156)
1492029: Jul 24 14:53:20.195 GST %MIVR-SS_VOIPMON_SRV-3-EXCEPTION:    at com.spanlink.VOIPMonitor.subsystem.LrmVoipManager.recovery(LrmVoipManager.java:444)
1492030: Jul 24 14:53:20.195 GST %MIVR-SS_VOIPMON_SRV-3-EXCEPTION:    at com.spanlink.VOIPMonitor.subsystem.VoipServerHeartbeatThread.run(VoipServerHeartbeatThread.java:50)
1492031: Jul 24 14:53:20.195 GST %MIVR-SS_VOIPMON_SRV-3-EXCEPTION:    at com.cisco.executor.impl.ExecutorStubImpl$RequestImpl.runCommand(ExecutorStubImpl.java:690)
1492032: Jul 24 14:53:20.195 GST %MIVR-SS_VOIPMON_SRV-3-EXCEPTION:    at com.cisco.executor.impl.ExecutorStubImpl$RequestImpl.run(ExecutorStubImpl.java:486)
1492033: Jul 24 14:53:20.195 GST %MIVR-SS_VOIPMON_SRV-3-EXCEPTION:    at com.cisco.executor.impl.ExecutorStubImpl$RequestImpl.run(ExecutorStubImpl.java:762)
1492034: Jul 24 14:53:20.196 GST %MIVR-SS_VOIPMON_SRV-3-EXCEPTION:    at EDU.oswego.cs.dl.util.concurrent.PooledExecutor$Worker.run(PooledExecutor.java:776)
1492035: Jul 24 14:53:20.196 GST %MIVR-SS_VOIPMON_SRV-3-EXCEPTION:    at com.cisco.executor.impl.PooledExecutorStubImpl$1$WorkerImpl.run(PooledExecutorStubImpl.java:99)
1492036: Jul 24 14:53:20.196 GST %MIVR-SS_VOIPMON_SRV-3-EXCEPTION:    at com.cisco.util.ThreadPoolFactory$ThreadImpl.run(ThreadPoolFactory.java:853)
1492037: Jul 24 14:53:20.196 GST %MIVR-SS_VOIPMON_SRV-3-VOIP_OPERATION_ERROR:VOIP subsystem operation error: Module Name=LrmVoipManager.recovery,A specific description for a trace=fail to read OPEN_CONF msg returned is null,Exception=
1492038: Jul 24 14:53:20.781 GST %MIVR-CFG_MGR-7-UNK:BSSession:heartbeat::BSSocket.nextInvokeId=130947
1492039: Jul 24 14:53:20.781 GST %MIVR-CFG_MGR-7-UNK:BSMessageWriter-1.writeMessage-> about to write bootstrap message = HEARTBEAT_REQ[length=-1,invokeId=130947]
1492040: Jul 24 14:53:20.828 GST %MIVR-CFG_MGR-7-UNK:BSMessageReader-1.run-> message read: HEARTBEAT_CONF[length=4,invokeId=130947]
1492041: Jul 24 14:53:25.784 GST %MIVR-CFG_MGR-7-UNK:BSSession:heartbeat::BSSocket.nextInvokeId=130948
1492042: Jul 24 14:53:25.785 GST %MIVR-CFG_MGR-7-UNK:BSMessageWriter-1.writeMessage-> about to write bootstrap message = HEARTBEAT_REQ[length=-1,invokeId=130948]
1492043: Jul 24 14:53:25.825 GST %MIVR-CFG_MGR-7-UNK:BSMessageReader-1.run-> message read: HEARTBEAT_CONF[length=4,invokeId=130948]
