Hi Cisco support team and all,
I have a problem using the Cisco RV320 to replace a consumer router for simple internet sharing usage in my company.
The problem is after all set the router work just fine on internet. After a day or two, the internet connection is lost. Intranet works fine, I can ping the computers in intranet and ping the RV320 internal IP. ping outside world is failed.
Our ISP provide a cable modem and a router linksys WRT54GS. The ISP provide 5 fixed IP, and I just use the RV320 to get one of the IP (static IP setting) for internet sharing.
Firmware is the most updated 1.1.1.06
Only 1 WAN is connected. I set to smart link backup mode.
In WAN 1 interface setting, it is a static IP setting, I tried to enable or disable "Enable Network service detection" but both get the same problem. When enabled I tried to check more options like ping 8.8.8.8 or google.com.
In WAN 2 I have disabled the "Network service detection". I also have disabled the WAN 2 service in "Port Management"
I was frustrated as I assume this is just a drop in replacement with the previous consumer router. Please help or anybody experience the same issue?
YP
