Warning message
Cisco WLC 2504 with AIR-CAP2702E-x-K9 not working
Aug 4th, 2014
I have a really simple scenario using WLC2504 (version 7.6.120.0) with a new AIR-CAP2702. I have just one WLAN configured in the vlan3 and a DHCP server for this WLAN, but when I try to connect the network is saying "Impossible to connect to the network" and I cannot associate.
Am I missing something? I just followed the config manual and I don't find the issue.
The WLC is connected to a SG-200-50 switch port with three vlans (vlan1 as untagged, vlan 2 and 3 are tagged).
This is the config for the WLC2504:
config acl layer2 rule add TEST_L2 1
config acl layer2 rule action TEST_L2 1 permit
config acl layer2 rule ethertype TEST_L2 1 2048 65535
config acl layer2 create TEST_L2
config acl layer2 apply TEST_L2
config acl rule add TEST 1
config acl rule source port range TEST 1 0 65535
config acl rule action TEST 1 permit
config acl rule destination port range TEST 1 0 65535
config acl rule add TEST 65
config acl rule source port range TEST 65 0 65535
config acl rule destination port range TEST 65 0 65535
config acl create TEST
config acl apply TEST
config dhcp address-pool "DHCP para VLAN3" 192.168.1.10 192.168.1.15
config dhcp dns-servers "DHCP para VLAN3" 192.168.1.4 8.8.8.8
config dhcp lease "DHCP para VLAN3" 86400
config dhcp address-pool "DHCP red WLC" 10.10.100.35 10.10.100.45
config dhcp lease "DHCP red WLC" 86400
config dhcp network "DHCP para VLAN3" 192.168.1.0 255.255.255.0
config dhcp network "DHCP red WLC" 10.10.100.0 255.255.255.0
config dhcp create-scope "DHCP para VLAN3"
config dhcp domain "DHCP para VLAN3" admin.testing.com
config dhcp default-router "DHCP para VLAN3" 192.168.1.249
config dhcp enable "DHCP para VLAN3"
config dhcp create-scope "DHCP red WLC"
config dhcp enable "DHCP red WLC"
config license boot base
config sysname WLC-TESTING
config 802.11a cac voice sip bandwidth 64 sample-interval 20
config 802.11a cac voice sip codec g711 sample-interval 20
config advanced probe limit 2 500
config advanced 802.11a profile foreign global 50
config advanced 802.11a channel add 36
config advanced 802.11a channel add 40
config advanced 802.11a channel add 44
config advanced 802.11a channel add 48
config advanced 802.11a channel add 52
config advanced 802.11a channel add 56
config advanced 802.11a channel add 60
config advanced 802.11a channel add 64
config advanced probe-limit 2 500
config advanced 802.11b profile foreign global 50
config advanced 802.11b channel add 1
config advanced 802.11b channel add 6
config advanced 802.11b channel add 11
config country ES
config wps client-exclusion ip-theft disable
config switchconfig strong-pwd lockout attempts mgmtuser 3
config switchconfig strong-pwd lockout time mgmtuser 5
config interface port management 1
config interface address management 10.10.100.30 255.255.255.0 10.10.100.249
config interface dhcp management primary 10.10.100.30
config interface address virtual 1.1.1.1
config interface port vlan3 1
config interface acl vlan3 TEST
config interface address dynamic-interface vlan3 192.168.1.1 255.255.255.0 192.168.1.249
config interface create vlan3 3
config interface dhcp dynamic-interface vlan3 primary 10.10.100.30
config interface vlan vlan3 3
config interface port vlan2 1
config interface address dynamic-interface vlan2 172.16.1.2 255.255.0.0 172.16.1.1
config interface create vlan2 2
config interface vlan vlan2 2
config trapflags ap ssidkeyconflict enable
config trapflags ap register enable
config trapflags ap authfailure enable
config trapflags ap modechange enable
config trapflags ap interfaceup enable
config trapflags ap timesyncfailure enable
config trapflags stpmode disable
config trapflags rogueap disable
config trapflags client 802.11-deauthenticate enable
config trapflags client 802.11-associate enable
config trapflags client 802.11-authfail enable
config trapflags client nac-alert enable
config trapflags client excluded enable
config trapflags client max-warning-threshold enable
config trapflags client authentication enable
config trapflags client 802.11-disassociate enable
config trapflags client 802.11-assocfail enable
config wlan session-timeout 3 1800
config wlan exclusionlist 3 60
config wlan broadcast-ssid enable 3
config wlan interface 3 vlan3
config wlan mfp client enable 3
config wlan create 3 WLC-PROFES WLC-PROFES
config wlan wmm allow 3
config wlan security wpa akm 802.1x disable 3
config wlan security wpa wpa2 ciphers aes disable 3
config wlan security wpa wpa2 disable 3
config wlan security wpa disable 3
config wlan security web-auth server-precedence 3 local radius ldap
config wlan enable 3
config mobility group domain testing
config certificate generate webadmin
config network rf-network-name testing
config network webmode enable
config network master-base enable
config network multicast global enable
config network multicast igmp snooping enable
config network multicast l2mcast disable service-port
config network multicast l2mcast disable virtual
config mdns profile service add default-mdns-profile AirPrint
config mdns profile service add default-mdns-profile AirTunes
config mdns profile service add default-mdns-profile AppleTV
config mdns profile service add default-mdns-profile HP_Photosmart_Printer_1
config mdns profile service add default-mdns-profile HP_Photosmart_Printer_2
config mdns profile service add default-mdns-profile Printer
config mdns profile create default-mdns-profile
config mdns service origin all AirPrint
config mdns service query enable AirPrint
config mdns service create AirPrint _ipp._tcp.local. origin all lss disable query enable
config mdns service origin all AirTunes
config mdns service query enable AirTunes
config mdns service create AirTunes _raop._tcp.local. origin all lss disable query enable
config mdns service origin all AppleTV
config mdns service query enable AppleTV
config mdns service create AppleTV _airplay._tcp.local. origin all lss disable query enable
config mdns service origin all HP_Photosmart_Printer_1
config mdns service query enable HP_Photosmart_Printer_1
config mdns service create HP_Photosmart_Printer_1 _universal._sub._ipp._tcp.local. origin all lss disable query enable
config mdns service origin all HP_Photosmart_Printer_2
config mdns service query enable HP_Photosmart_Printer_2
config mdns service create HP_Photosmart_Printer_2 _cups._sub._ipp._tcp.local. origin all lss disable query enable
config mdns service origin all Printer
config mdns service query enable Printer
config mdns service create Printer _printer._tcp.local. origin all lss disable query enable
config database size 2048
config 802.11b 11gsupport enable
config 802.11b cac voice sip bandwidth 64 sample-interval 20
config 802.11b cac voice sip codec g711 sample-interval 20
config ap packet-dump capture-time 10
config ap packet-dump truncate 0
config ap packet-dump buffer-size 2048
config mgmtuser add encrypt cisco 1 60b1a65ef9a0f69437eb739a615c088e 78976c29bc00d9a0eb5a4c843a0abb8e1b5b122c 16 8d5a6d1413464de026722d6ea58c74170000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 read-write
Thanks.
Vinod Arya Wed, 08/13/2014 - 09:34
  • Cisco Employee,
Is your client getting an IP Address? What kind of l2/l3 security configured on the WLAN?
Is authentication successful? Share following ouptut :
  • show wlan summary
  • show wlan wlan_number/id
Also, enable debug and share the debug ouptut when a client tries to join the WLAN, enable following debug :
  • debug client client_mac_addr
One the debug is over, disable it with debug disable-all.
-Thanks
Vinod
**Encourage Contributors. RATE Them.**
