Cisco phone registering on Empty CME flash, and upgrade issue
Aug 4th, 2014
I have two issues:
1. I have a CME that had a lot of files on it and Cisco phones were registering with sccp files.
I saved his flash and cleared it. now there is only the .bin file and NO sccp files.
How is it possible that the phones I connect to the CME still registering with sccp files? aren't the phones taking the files from the CME every time??
2. I have two 7942 IP phones with the files sccp42.8-3-2S and sccp42.8-4-1S.
I want to upgrade them to be working in SIP protocol.
how should I do it? to what file should I upgrade?
CME version is 8.6
thanks a lot!
Tagir Temirgaliyev Tue, 08/05/2014 - 04:45
  • Silver, 250 points or more
1. phones NOT taking the files from the CME every time. only when in flash latest firmware
2. cmterm-7942_7962-sip.9-3-1SR4-1.cop.sgn
do not forget rate post
michael o'nan Mon, 08/25/2014 - 13:57
What do you mean by save and clear flash? How are you viewing flash? If I'm not mistaken show flash will show the .bin file and dir flash: will show all the phone files.
