08-05-2014 11:30 AM - edited 03-11-2019 09:34 PM
Hi, I'm setting up my first ASA. I'm able to serial into the device and have setup inside and management interfaces however none of the interfaces are able to establish link state with other devices on the LAN.
The interfaces doesn't appear to be sending out or responding to arp requests. idea's?
08-05-2014 12:45 PM
Can you post the config?
08-05-2014 01:18 PM
Thanks for the reply. I looked in the config and saw that e0/0 was in a shut down state. Trying to remove it wouldn't work so I ran setup again. It removed the shut down state and resolved the linkstate issue.
Moving forward....thank you for your assistance
08-05-2014 01:31 PM
That is what I was going to check.
Mike
