08-05-2014 11:32 PM - edited 03-04-2019 11:29 PM
I am trying to configure the ap on a Cisco 887VAMW router but cannot get the Dot11Radio 0 interface to come up, it is stuck on 'reset'
Here is my config:
ap(config)#do sh run
Building configuration...
Current configuration : 2964 bytes
version 12.4
no service pad
service password-encryption
hostname ap
logging rate-limit console 9
enable secret 5 $1$E0no$MTZp.nseyRv.1m0Q.Rx4N.
no aaa new-model
dot11 syslog
dot11 ssid XXX
vlan 1
authentication open
authentication key-management wpa version 2
guest-mode
mbssid guest-mode dtim-period 1
wpa-psk ascii 7 113C4A2733400909366931
username admin secret 5 $1$eYC5$ePSDBvwD6VLzMrZxKtBus.
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 1 mode ciphers aes-ccm
broadcast-key vlan 1 change 3600 membership-termination capability-change
ssid XXX
antenna gain 0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface GigabitEthernet0
description the embedded AP GigabitEthernet 0 is an internal interface connecting AP with the host router
no ip address
no ip route-cache
bridge-group 1
interface BVI1
ip address dhcp client-id GigabitEthernet0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
banner exec ^CC
% Password change notice.
Default username/password setup on AP is cisco/cisco with privilege level 15.
It is strongly suggested that you create a new username with privilege level
15 using the following command for console security.
username <myuser> privilege 15 secret 0 <mypassword>
no username cisco
Replace <myuser> and <mypassword> with the username and password you want to
use. After you change your username/password you can turn off this message
by configuring "no banner login" and "no banner exec" in privileged mode.
^C
banner login ^CC
no username cisco
^C
line con 0
privilege level 15
login local
no activation-character
line vty 0 4
login local
Can anyone assist me on this one?
Thanks alot
Solved! Go to Solution.
08-06-2014 05:47 AM
If you want an MBSSID setup, you have lacking configuration and incorrect as well:
I'll give you a new sample:
dot11 ssid TEST
vlan 1
authentication mode open
wpa-psk ascii <yourpassword>
mbssid guest-mode -One of your mistakes, if you want mbssid, only this line is required
interface dot11radio 0
encryption vlan 1 mode ciphers tkip
ssid TEST
mbssid
no shutdown
interface dot11radio 0.1
encapsulation dot1q 1 native
bridge-group 1
interface gigabitethernet0.1
bridge-group 1
Done!
In your setup, the AP does not know that VLAN1 is the native, its native is the native radio,
that is why we create a sub-interface for it :)
Also 'bridge-group 1' should always exist in the native VLAN,
If you want to add more SSID, just do the same (of course skipping the 'native' on the rest) and adding another bridge-group ex; bridge-group 2 vice versa
08-06-2014 04:18 AM
08-06-2014 05:47 AM
dot11 ssid TEST
vlan 1
ssid TEST
mbssid
no shutdown
bridge-group 1
bridge-group 1
Done!
