Warning message
Cisco 4503 unexpectedly reload "System returned to ROM by watchdog timer expired"
Aug 6th, 2014
In five days the router made two unexpectedly reloads with the following message:
show ver
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-IPBASE-M), Version 12.2(52)SG, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Tue 12-May-09 16:47 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x11B8F004
ROM: 12.2(31r)SGA2
Dagobah Revision 226, Swamp Revision 34
4500 uptime is 1 hour, 6 minutes
System restarted at 09:21:23 UTC Tue Aug 5 2014
System image file is "bootflash:cat4500-ipbase-mz.122-52.SG.bin"
cisco WS-C4503-E (MPC8245) processor (revision 10) with 262144K bytes of memory.
MPC8245 CPU at 266Mhz, Supervisor II+
Last reset from Watchdog
3 Virtual Ethernet interfaces
96 FastEthernet interfaces
2 Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
The flash dont have crash info, the logging dont have any information.
The only thing that is different from the first unexpectedly reload is the configuration of some interfaces and ISE configuration, example:
aaa authentication login default local
aaa authentication enable default enable
aaa authentication dot1x default group ISE
aaa authorization network default group ISE
aaa accounting dot1x default start-stop group ISE
interface FastEthernet2/4
 description 802.1x Enabled
 switchport mode access
 authentication host-mode multi-host
 authentication order mab dot1x
 authentication priority mab dot1x
 authentication port-control auto
 mab
 dot1x pae authenticator
 dot1x timeout tx-period 3
 spanning-tree portfast
 spanning-tree bpduguard enable
Ricardo
