Warning message
Integrating a fax machine into CUCM 9
Aug 6th, 2014
Dear All,
We've having a new request concerning Fax Machines integration.
Kindly confirm the possibility of integrating an existing fax machine into CUCM 9
we have a CUCM 9 cluster with Voice gateway  includng E1 ISDN PRI.
If possible kindly provide details about protocols and feasibikity.
Awaiting your feedback,
Akhilesh Nambiyath Tue, 10/21/2014 - 05:45
If you are looking for a Advanced Solution go for Imagicle Stonefax.
Or else by using ATA u can integrate fax machines over CUCM
tbcadministrator Thu, 02/11/2016 - 03:43
Hi Akhilesh,
we have the same requirement we want to integrate our FAX machine with imagicle server how can we do it ?
Andy J Tue, 10/21/2014 - 13:45
For our analog faxes we are using a Cisco vg224, which gives you 24 analog ports (They make smaller ones too). We are also have an Xmedius fax server which allows users to send and receive faxes from the desktops.
