Warning message
agent is unable to login
Answered Question
Aug 8th, 2014
We have issue with agent logging in.
Trying to integrate our UCCE (Staging) with seibel  with CTI server. We have installed the connector verified through the config .... all is intact as par the recommended guidelines of seibel vendor.
As well as Services are also active from UCCE end. Agent instrument is also participating in the Jtapi application user.
When attempted to login with the CTI  tool , we are getting error : " Error: Login could not be performed- Possible cause are invalid instrument; Media termination Problem or other CM issue." .
Verified through the procmon : enclosed the snapshot...
not sure if i need to upgrage the CUCM to overcome this issue.
Any thoughts would be appreciated.
CUCM : 8.5.1.1000
Agent CTI toolkit: 8.5.7
Cheers,
Correct Answer by Chintan Gajjar about 3 years 1 week ago
hi,
there is a makecall utility comes with JTAPI when you install it on your machine for integration.
its located under,
C:\Program Files\JTAPITools\makecall (probably on your PG server)
use that utility to verify your JTAPI is working correctly.
go to command promp
move to that folderc (CD C:\Program Files\JTAPITools\makecall)
and run
java makecall <origin> <login> <password> <delay> <origin extension> <destination Extension>
exmaple
java makecall 192.168.50.5 pg1user pg1user 1000 23006 25000
where
192.168.50.5 is CUCM
pg1user, pg1user is username and password
1000 is delay in millisecond
23006 is the extension monitored by jtapi
and 25000 is extension i am trying to call
if this works then you JTAPI is working correct, you may possibly look at sieble.
if doesnt , then please try to reasociate/reset device.
regards
Chintan
Correct Answer by Jameson Gagnepain about 3 years 1 week ago
Is the agent extension included in an Extension Range in the Agent Targeting Rule List in UCCE?
-Jameson
Overall Rating: 5 (2 ratings)
Manjunath G Fri, 08/08/2014 - 05:45
seeing the message from jgw log  " 2424com,cisco.jtapi.invalidargumentExceptionImpl: Address 2424 is not in the provider's domain" .
Is this issue due to CTI manager??
Correct Answer
Chintan Gajjar Fri, 08/08/2014 - 09:58
  • Blue, 1500 points or more
hi,
its located under,
go to command promp
and run
exmaple
where
regards
Chintan
Manjunath G Fri, 08/08/2014 - 12:53
Thanks chintan ... will try this ...
@Jameson  -  We have device taget defined.. thanks
Just a quick ccheck .... Can a standalone CUCM node is allowed to participate in jtapi-pim connection with two different PG's??? my answer is Yes.... but just wanna be sure.
ie: two different PG server referencing to same single CUCM node for PIM.
Cheers
Chintan Gajjar Sat, 08/09/2014 - 02:28
In LAB environment,
Yes its possible.
in production:
i dont have answer on cisco's support on this. document says max of 5 are allowed for CUCM 8.6 or later and max of 3 for previous release.
basically if you have only one subscriber running CTI manager, you will loose redundacy from CUCM side. if your CTI is down, all the PGs will be inactive.
but coming to your question:
we have this configuration in place for one site, its cluster of 6 subscriber and 1 pub.
and 4 PGs are connected to them. and for one subsciber pair 2 PG connection are configured.
regards
Chintan
~please rate all helpful posts
Correct Answer
Jameson Gagnepain Fri, 08/08/2014 - 08:34
  • Silver, 250 points or more
  • Community Spotlight Award,
    Member's Choice, March 2015
-Jameson
Manjunath G Fri, 08/15/2014 - 02:40
Thanks for all the valuable inputs ... it was jtapi issue. Though the CTI Manager in cucm had problem PIM was stilll showing as active (even after recycle of services).
Hint to Rest all: RTMT is also useful to find the 'jtapi'applicate user route points to validate  CTI controlled RP's.
Hence we have redirected to another node...& all working fine.
