MGCP FXO Picking random FXO ports for outgoing calls.
Aug 10th, 2014
i,
I have a IP Telephony setup running on MGCP . I have one FXO card (4 ports)  in which 2 ports are using and 2 PSTN lines are connected to my router.
The issue is that when outgoing calls make picking randomly fxo ports.
I want all the 2 users to use their own FXO port assigned to them.
I have configured my cucm and mgcp gateway in such a way that I want every user to use their own FXO port for making incoming and outgoing calls. But still the router is picking random FXO ports. How can I restrict user to user their own FXO port for making incoming and outgoing calls. Any other suggestion or tip will be very helpful to me.
Following are the 2 PSTN numbers which i have assigned to FXO ports:
voice-port 0/0/0 = 17538
voice-port 0/1/3 = 4640
Thanks in advance
Nithin
islam.kamal Sun, 08/10/2014 - 04:58
  • Red, 2250 points or more
Hello
For inbound calls , you can go device - gateway -  port - configure under attendant DN " the resquired DN which you need to hit it".
For outgoing calls can you check the below:-
You can configure two different RGs , one for 0/0/0 & other for  0/1/3. Then do two different RLs
For example , i need extension 4001 need to call mobile calls  using port 0/0/0. So by using MGCP , it will be so eazy
1)Create PT_Mobile
2)CSS_CallsToFXO
3)Make RG for port 0/0/0 , then RL
4)under RP 9XXXXXXXXXX - specify route partition "PT_mobile"
5)Assign CSS for the ext 4001 and for gateway for port 0/0/0 . dial now from 4001 the call go out using port 0/0/0. same for 0/1/3.
Note: if you have other RP which use 9 as outgoing access code , you can change it to any digit.as 8 for outgoing access code
please rate all useful information
