Warning message
issue while adding asa to prime infra 2.1 - buffer size exceeded
Answered Question
Aug 11th, 2014
I was trying to add a firewall ASA 5545-X with image 9.0.3 to prime infra 2.1 and faced below error message in firewall logs,
incoming SNMP request (584 bytes) from IP address <PI IP ADD> Port 14796 Interface "<int-name>" exceeds data buffer size, discarding this SNMP request.
SNMP configuration is okay in ASA and PI. While I was searching for similar cases, I came across below thread,
https://supportforums.cisco.com/discussion/11761921/exceeds-data-buffer-size-discarding-snmp-request
Similar issue but related to LMS and no workaround.
Just wanted to know, if anyone has experienced similar issue and what was the workaround/solution.
Many Thanks,
Girish
Correct Answer by AFROJ AHMAD about 3 years 1 week ago
Hi Girish,
 This is a device side BUG,
ENH - Increase maximum SNMP message size to 1472 bytes per RFC 3417
Known Fixed Releases:
100.8(51.1)
9.1(5.4)
100.8(40.75)
Thanks-
Afroz
***Ratings Encourages Contributors ****
Overall Rating: 5 (2 ratings)
Correct Answer
AFROJ AHMAD Mon, 08/11/2014 - 17:26
  • Cisco Employee,
Hi Girish,
100.8(51.1)
9.1(5.4)
100.8(40.75)
Thanks-
Afroz
girish_gavandi Wed, 08/13/2014 - 05:02
Hi afrahmad,
We upgraded the firewall image to 9.3(1) and reconfigured the SNMP and it started working. Prime Infrastructure now can poll the ASA for status and configuration archiving.
Thank for your response, much appreciated.
Girish
