Warning message
UCS Director 5 Workflow Tasks
Aug 13th, 2014
i cloned the task "OVF Import to VMware Cloud" from task library.
if i use this cloned custom task within a workflow, it doesn't deploy a ovf template.
This is the output from a workflow with the original task
Aug 13, 2014 11:13:05 UTC Request submitted
Aug 13, 2014 11:13:07 UTC Executing workflow item number 1
Aug 13, 2014 11:13:07 UTC Completed workflow item number 1, with status Completed
Aug 13, 2014 11:13:13 UTC Executing workflow item number 2
Aug 13, 2014 11:13:13 UTC Trigger context executeWorkFlowStep called
Aug 13, 2014 11:13:13 UTC Executing custom action custom-ovf-deployment (OVF Import to VMware Cloud)
Aug 13, 2014 11:13:13 UTC Initiating OVF content read from URL : file:/opt/infra/uploads/external/public/1407488922913/demo.ovf
Aug 13, 2014 11:13:13 UTC Policy Trace: Populating cluster/hostnode/datastore list for cloud teamix
Aug 13, 2014 11:13:13 UTC Policy Trace: Final Scope includes Host demoesx01
Aug 13, 2014 11:13:13 UTC Policy Trace: Final Scope includes Host demoesx02
Aug 13, 2014 11:13:14 UTC Policy Trace: After applying PrivateCloudComputingPolicy, scope has 2 hosts
Aug 13, 2014 11:13:14 UTC Policy Trace: Scope now includes host demoesx01 and it's datastores : 73c42fe99cc535fd96e45ab03bacc789,local_ds_demoesx01,5c3a0165a62d338bbbabb6eef9fed97d,demonfs01_demonap,nfsdemo,demonfs02_demonap
Aug 13, 2014 11:13:14 UTC Policy Trace: Scope now includes host demoesx02 and it's datastores : 73c42fe99cc535fd96e45ab03bacc789,local_ds_demoesx02,5c3a0165a62d338bbbabb6eef9fed97d,demonfs01_demonap,nfsdemo,demonfs02_demonap
Aug 13, 2014 11:13:14 UTC Policy Trace: Filtering storage scope for system disk type started.
Aug 13, 2014 11:13:14 UTC Policy Trace: Filtering data stores, ruleType=Include
Aug 13, 2014 11:13:14 UTC Policy Trace: Datastores in the include List 73c42fe99cc535fd96e45ab03bacc789
Aug 13, 2014 11:13:14 UTC Policy Trace: Removing Data store local_ds_demoesx01, not in the 'Include' list
Aug 13, 2014 11:13:14 UTC Policy Trace: Removing Data store 5c3a0165a62d338bbbabb6eef9fed97d, not in the 'Include' list
Aug 13, 2014 11:13:14 UTC Policy Trace: Removing Data store demonfs01_demonap, not in the 'Include' list
Aug 13, 2014 11:13:14 UTC Policy Trace: Removing Data store nfsdemo, not in the 'Include' list
Aug 13, 2014 11:13:14 UTC Policy Trace: Removing Data store demonfs02_demonap, not in the 'Include' list
Aug 13, 2014 11:13:14 UTC Policy Trace: Removing Data store local_ds_demoesx02, not in the 'Include' list
Aug 13, 2014 11:13:14 UTC Policy Trace: Filtering storage scope for system disk type completed.
Aug 13, 2014 11:13:14 UTC Policy Trace: No additional storage polices defined. Starting datastore filtering for default system type.
Aug 13, 2014 11:13:14 UTC Policy Trace: Completed datastore filtering for default system type.
Aug 13, 2014 11:13:14 UTC Policy Trace: After applying PrivateCloudStoragePolicy, scope has 2 hosts
Aug 13, 2014 11:13:14 UTC Policy Trace: No Portgroup name specified in the network policy, so no host filtering done
Aug 13, 2014 11:13:14 UTC Policy Trace: After applying PrivateCloudNetworkPolicy, scope has 2 hosts
Aug 13, 2014 11:13:14 UTC Policy Trace: After evaluating 0 rules, 2 hosts met the criteria
Aug 13, 2014 11:13:14 UTC Policy Trace: Host: demoesx01
Aug 13, 2014 11:13:14 UTC Policy Trace: Host: demoesx02
Aug 13, 2014 11:13:14 UTC Primary Allocated Cluster: ccp-cluster
Aug 13, 2014 11:13:14 UTC Primary Allocated Datastore: 73c42fe99cc535fd96e45ab03bacc789
Aug 13, 2014 11:13:14 UTC Primary Allocated ResourcePool: Resources
Aug 13, 2014 11:13:14 UTC Provisioning on primary host/datastore...
Aug 13, 2014 11:13:14 UTC OVF URL:/opt/infra/uploads/external/public/1407488922913/demo.ovf
Aug 13, 2014 11:13:15 UTC Found data store 73c42fe99cc535fd96e45ab03bacc789 which matched cluster ccp-cluster DC Mordor
Aug 13, 2014 11:13:15 UTC Initiating OVF deployment action.
Aug 13, 2014 11:13:15 UTC Initiating OVF content read from URL : file:/opt/infra/uploads/external/public/1407488922913/demo.ovf
Aug 13, 2014 11:13:17 UTC Initiating VMDK file upload
this is the output from my cloned task:
Aug 13, 2014 11:14:32 UTC Request submitted
Aug 13, 2014 11:14:37 UTC Executing workflow item number 1
Aug 13, 2014 11:14:37 UTC Completed workflow item number 1, with status Completed
Aug 13, 2014 11:14:43 UTC Executing workflow item number 2
Aug 13, 2014 11:14:43 UTC Trigger context executeWorkFlowStep called
Aug 13, 2014 11:14:43 UTC Executing custom action cdot1 (custom_readcDC)
Aug 13, 2014 11:14:43 UTC Executing custom script for readcDC
Aug 13, 2014 11:14:44 UTC Task #1 (cdot1 (custom_readcDC)) completed successfully in 0 seconds
Aug 13, 2014 11:14:44 UTC Input/Output values for Task #1 (cdot1 (custom_readcDC)):
Aug 13, 2014 11:14:44 UTC [Mapped Input: Select vDC = 2]
Aug 13, 2014 11:14:44 UTC [Mapped Input: OVF File = /opt/infra/uploads/external/public/1407488922913/demo.ovf]
Aug 13, 2014 11:14:44 UTC Completed workflow item number 2, with status Completed
Aug 13, 2014 11:14:49 UTC Executing workflow item number 3
Aug 13, 2014 11:14:49 UTC Completed workflow item number 3, with status Completed
it seems that there is something lost while cloning the task.
Does anybody have an idea what i'm forgot?
regards
Oliver
Related Content
