Warning message
FEX power supply fail/shutdown
Aug 15th, 2014
I have a FEX that shows Fail/Shutdown when I issue the command "show environment fex".  However, the status light of the FEX power supply is green.  None of my other FEXes show this behavior.  I also replaced the power supply but nothing changed.  Need your help.
Reza Sharifi Sun, 08/17/2014 - 02:41
  • Cisco Designated VIP,
    2017 LAN
Since you have already replaced the power supply and sttill have the same issue, open a ticket with TAC to help you resolve it.  It might be a code issue that is effecting that FEX.
3diamondt Fri, 08/22/2014 - 10:34
Thanks Reza! The FEX was back to normal after a reboot.
Reza Sharifi Fri, 08/22/2014 - 10:42
    2017 LAN
Glad to hear the issue is resolved.
