Warning message
Cisco ISR to BlueCoat Cloud Proxy
Aug 15th, 2014
Hi all, I'm wondering if anyone has done ipsec tunnel to BlueCoat Proxy from ISR G2. I do have a security license on the router. All i know is that they use ikev1 psk to establish the connection... please let me know. Thanks
nkarthikeyan Sat, 08/16/2014 - 01:48
  • Gold, 750 points or more
Yeap. You have to use ikev1 and psk for this ipsec establishment with BC cloud proxy.
Recommendations:
ikev1
presharedkey
IKEv1 Policy:
pre-share-aes-256-sha
pre-share-aes-sha
Mode: Tunnel Mode
IPSec Policy:
PFS should be enabled
NAT-T should be disabled
DH Group: 5
Local Network as it on actuals and remote network type any
Connection should be bi-directional
Service should be enabled for http/https and nat to be done for the same..... with disabling proxy-arp
after configuring this you can try a http/https access to a website....
Even that will show you which pod you have connected with...
Karthik
Ji-Won Park Sat, 08/16/2014 - 09:31
IPSEC is established between BC Cloud and my ISR now... However, I am facing a little challenge here.
I have NAT-OVERLOAD to my cellular network which is connected to my intenal network in GRE/IPSEC (BGP) and I need to somehow forward my client traffic to the BC Cloud IP address.
Diagram:
Tunnel1 SW--ISR---------GRE/IPSEC-------------INTERNAL-DC
SW--ISR-----------------------IPSEC------------------BC Cloud
Has anyone gone through this exercise? Please let me know.
Ji-Won Park Sat, 08/16/2014 - 06:57
I believe my ISR supports IKEv2 only.. Does it fall back to IKEv1??
## Here's my config
crypto isakmp policy 1
 encr aes 256
 authentication pre-share
 group 5
crypto isakmp key [PSK] address [CLOUD-IP]  no-xauth
crypto ipsec transform-set BC-Cloud esp-aes esp-sha256-hmac
 mode tunnel
crypto map vpn 1 ipsec-isakmp
 set peer [CLOUD-IP]
 set transform-set BC-Cloud
 match address 175
access-list 175 permit ip [internal Client IP] any
interface cellular 0/0/0
 crypto map vpn
Please note that I only provided IPSEC related configuration here. Assume that cellular interface, NAT, routing all other components are working as expected.
Ji-Won Park Sat, 08/16/2014 - 18:07
Anyone...??
The tunnel has been created, but I still don't know how i should be forwarding packets as I am using cellular interface.. I have 'nat overload to Cellular0/0/0' and my default route pointing to Cellular0/0/0..
