Warning message
Help | SIP Trunk Through CME IOS 15.1 Towards SIP ISP | Outgoing Call Issue
Aug 16th, 2014
My phones are registered with the CME and i have purchased a Sip trunk . After doing the configuration from my side i am not able to make an outgoing call to the PSTN number through SIP trunk.
I am attaching two files :
1 Router running configuration
2 Debug messages of SIP
Kindly Find the attachment below .
Tagir Temirgaliyev Sat, 08/16/2014 - 08:52
  • Silver, 250 points or more
Sent:
REGISTER sip:gw2.sip.us:5060 SIP/2.0
Authorization: Digest username="5245798725",realm="gw2.sip.us",uri="sip:gw2.sip.us:5060",response="7ed5ba1aeac06c817b85c2dbe27367e7",nonce="U+ytflPsqybfv42Ryk9al/95ESy/wYeLXU1gUBM4lrBPyTI8M1DbfH09zxfD",cnonce="D9DAF3A4",qop=auth,algorithm=md5,nc=00000001
Content-Length: 0
Received:
SIP/2.0 401 Unauthorized
WWW-Authenticate: Digest realm="gw2.sip.us", nonce="U+ytgFPsqygibbsnBlbZSJnSzv9GWaFdXU1gUBM4lrBPyTI8M1DbfFH7dCnA", qop="auth"
Content-Length: 0
you sent register and you recieved unauthorized. it looks like username/password incorrect
and dont forget to rate post
Tagir Temirgaliyev Sun, 08/17/2014 - 07:34
may be calling or called number incorrect. send debug to provider
Ayodeji Okanlawon Sun, 08/17/2014 - 12:48
  • Cisco Designated VIP,
    2017 IP Telephony
What is your ITSP saying. You need to work with them to resolve this one..
The invite you sent contains yoru authentication credentials..
Sent:
INVITE sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/UDP 192.235.68.162:5060;branch=z9hG4bK8FBA1C34
Remote-Party-ID: "US-Test" <sip:[email protected]>;party=calling;screen=no;privacy=off
From: "US-Test" <sip:[email protected]>;tag=2759C404-12A3
To: <sip:[email protected]>
Date: Thu, 14 Aug 2014 13:42:57 GMT
Call-ID: [email protected]
Proxy-Authorization: Digest username="5245798725",realm="gw2.sip.us",uri="sip:[email protected]:5060",response="5c0780df149e2095ffa2cc3a82324cf1",nonce="U+ytbVPsqxVLlM+Q+FKbz21eW/PJWZ/0qmlfGHm8LYFzoZ5QH6VR0zsOho3C",cnonce="966E3696",qop=auth,algorithm=md5,nc=00000001
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 253
Next they are requesting authorization for using the same credentials you already sent to them
Received:
SIP/2.0 407 Proxy Authentication Required
Via: SIP/2.0/UDP 192.235.68.162:5060;branch=z9hG4bK8FBA1C34;rport=59195
To: <sip:[email protected]>;tag=6b55604b003175432ccabd664d6002bd.2cff
CSeq: 102 INVITE
Proxy-Authenticate: Digest realm="gw2.sip.us", nonce="U+ytbVPsqxVY3f1Rcwe6MFkPUG1ZvsHtqmlfGHm8LYFzoZ5QH6VR01H7YxjA", qop="auth"
You need to ask them what is wrong with your authentication credentials..
You also need to verify what realm you  need to be using. You have configured gw1.sip.us. But I also see gw2.sip .us..which is which?
Content-Length: 0
Related Content
