PAT blocking IPsec
jiripijacek
I have problem with Portforwarding and IPsec tunnel:
When I set PAT:
ip nat inside source static tcp 192.168.10.207 101 WAN_IP 101 extendable
then this port is unavailable for remote PCs in other site via IPsec 192.168.7.0.
I have also set NAT on interface
ip nat inside source list NAT interface GigabitEthernet0/0 overload
ip access-list extended NAT
 deny   ip 192.168.10.0 0.0.0.255 192.168.7.0 0.0.0.255
 permit 192.168.10.0 0.0.0.255 any
this mean nonat to remote site :192.168.7.0 and natting to other
Everithings going well, but portforwarded ports dont.
Thanks for answers.
zeuscyril
Level 4
Level 4
hi,
you have to use route-map for this problem
create the NAT access-list and apply with route-map and then creat nat traffic  with the route map
ex:
ip nat inside source static tcp 192.168.0.7 6004 y.y.y.y 6004 route-map nonat extendable
route-map nonat permit 10
 match ip address 101
the 101 will be your NAt access-list which you will have deny statement for VPN Networks and all other networks will be permitted.
if you configure like this your Natted IP also will work in the VPN.
if it is helpful please rate it.
cyril
