Warning message
Static NAT on an ASA running version 8.3 not working
Answered Question
Aug 18th, 2014
I'm testing a fairly simple static NAT setup and I can't seem to get it working.
Here's the situation. I have two ASA5510 working in Active/Standby mode. It's all good, everytihng works there. This high availability cluster is connected on the inside interfaces to switches and on the outside interfaces to routers. All is working as far as IP connectivity is concerned. Here the IP setup:
interface Ethernet0/0
 nameif outside
 security-level 0
 ip address 10.1.5.2 255.255.255.0
interface Ethernet0/1
 nameif inside
 security-level 100
 ip address 10.1.6.1 255.255.255.0
object network obj-10.1.6.10
 host 10.1.6.10
 nat (inside,outside) static 149.13.0.21
So when I go on the routers, connected to the outside interfaces, and I send some traffic subject to the configured NAT - it fails:
BB2#ping 149.13.0.21
Sending 5, 100-byte ICMP Echos to 149.13.0.21, timeout is 2 seconds:
Success rate is 0 percent (0/5)
But on the ASA - the traffic is "matched" but not translated...
Rack1ASA2/NAT# show nat
Auto NAT Policies (Section 2)
1 (inside) to (outside) source static obj-10.1.6.10 149.13.0.21
    translate_hits = 0, untranslate_hits = 5
So why the NAT rule does not perform any translations? Do the security levels on the ASA play any role in that?
When I initiate traffic from inside to the outside - it also fails, but there are no hits what so ever on the NAT rule.
Am I missing something?
Correct Answer by Karsten Iwen about 2 years 12 months ago
it shows that the ASA would use the right translation when the internal server communicates to the outside world. So lets simulate what would happen on the ASA when the traffic is coming from the outside:
packet-tracer input outside tcp 10.1.5.100 1234 149.13.0.21 80
Overall Rating: 5 (2 ratings)
Karsten Iwen Mon, 08/18/2014 - 10:57
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Firewalling, VPN
NAT is only one part of the communication. Did you allow the traffic in the Interface-ACLs? For the outside-ACL, remember that you need to configure the destination with the real IP (10.1.6.10) of the server.
Boyan Sotirov Mon, 08/18/2014 - 11:01
Thank you for your fast response on this thread!
How do I do that? Do I need an ACL for both inside and outside interface?
Do I have to specifically allow traffic from the inside to the outside, and from the outside to the inside interface?
10.1.6.10 actually should be private (inside) address of the internal host. Maybe I've configured that wrong...
Karsten Iwen Mon, 08/18/2014 - 11:12
You always need an ACL to communicate from a lower to a higher security-level. So you need one for outside->inside.
Look at "sh run access-group" and you see which ACL is bound to the outside interface. There you need something like
access-list NAMEofACL ext permit icmp any object obj-10.1.6.10 echo
or
access-list NAMEofACL ext permit tcp any object obj-10.1.6.10 eq 80
If the above show-command also shows an ACL on the inside interface, then also an entry is needed there.
For testing with ping make sure that you have icmp-inspection enabled:
policy-map global_policy<br />&nbsp;class inspection_default<br />&nbsp; inspect icmp
Boyan Sotirov Mon, 08/18/2014 - 14:28
As this is a test environment, I've started with an empty configuration. So ther's not ACL on any inteface.
Rack1ASA2/NAT# show running-config access-list
access-list OUTSIDE extended permit ip any object obj-10.1.6.10
access-list OUTSIDE extended permit ip any object obj-149-13-0-21
And I aplied it on the outside interface:
Rack1ASA2/NAT# show runn access-grou
access-group OUTSIDE in interface outside
But it still does not work...
Karsten Iwen Mon, 08/18/2014 - 15:10
Can you ping the inside server from the ASA?
And show your whole config please.
Boyan Sotirov Tue, 08/19/2014 - 05:03
Here's the config:
ASA Version 8.3(2) <context>
hostname NAT
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
 nameif outside
 security-level 0
 nameif inside
 security-level 100
 host 10.1.6.10
object network obj-149-13-0-21
 host 149.13.0.21
pager lines 24
mtu outside 1500
mtu inside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh timeout 5
no threat-detection statistics tcp-intercept
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns migrated_dns_map_2
 parameters
  message-length maximum client auto
  message-length maximum 512
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
  inspect icmp
policy-map type inspect dns migrated_dns_map_1
 parameters
service-policy global_policy global
Cryptochecksum:5a93a8ae2dd29b4ca5a8a4acc26f52d8
: end
Karsten Iwen Tue, 08/19/2014 - 05:13
I just realise that you have a private IP on your outside interface. That means that there is another device in front of your ASA that has to do the translation for the public address-space. There you have to configure NAT.
Or, if it is just a DSL-router, you should reconfigure that device to "bridge"-mode. Then you have the public IP on the ASA what would make all less complex.
Boyan Sotirov Tue, 08/19/2014 - 08:22
Karsten,
It's actually a test environment ;) But it's the way it should be.
To explain a little bit. I'm testing a scenario where I have two WAN routers, behind them two ASAs in an Active/Standby configuration, behind the ASAs - there's the local LAN.
The idea is, that the WAN routers will advertise the privat prefix over BGP to two different providers. The link between the WAN routers and ASAs will use HSRP, so that the active ASA will send over the outbound traffic to the Active HSRP router.
The idea is to have the ASA doing the NAT from the public prefix to the private one. I would like to have a redundanc and stateful NAT and I want my NAT to be independent of the WAN routers. So the link between the ASA and the WAN routers above is just an internal connection. That's where the complexity comes from... But I can't seem to get the ASA cluster doing the NAT, that's the issue here.
Karsten Iwen Tue, 08/19/2014 - 08:37
ok, what output does the following command give:
packet-tracer input inside tcp 10.1.6.10 1234 10.1.5.100&nbsp;80
Boyan Sotirov Tue, 08/19/2014 - 09:01
That's quite a handy command :)
Rack1ASA2/NAT# packet-tracer input inside tcp 10.1.6.10 1234 $
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
MAC Access list
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   10.1.5.0        255.255.255.0   outside
Phase: 3
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 4
Type: FOVER
Subtype: standby-update
Result: ALLOW
Config:
Phase: 5
Type: NAT
Subtype:
Result: ALLOW
Config:
Static translate 10.1.6.10/1234 to 149.13.0.21/1234
Phase: 6
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 7
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 17721, packet dispatched to next module
Result:
input-interface: inside
input-status: up
input-line-status: up
output-interface: outside
output-status: up
output-line-status: up
Action: allow
But it seems to me that in this direction - the traffic is send through the ASA, at least according to the packet-tracer...
Correct Answer
Karsten Iwen Tue, 08/19/2014 - 09:08
Boyan Sotirov Tue, 08/19/2014 - 09:26
There you go...
Rack1ASA2/NAT# packet-tracer input outside tcp 10.1.5.100 123$
Phase: 1
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
NAT divert to egress interface inside
Untranslate 149.13.0.21/80 to 10.1.6.10/80
Phase: 2
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
Phase: 3
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 4
Type: FOVER
Result: ALLOW
Config:
Phase: 5
Type: NAT
Subtype: rpf-check
Result: ALLOW
Config:
Phase: 6
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 7
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 17973, packet dispatched to next module
Result:
input-interface: outside
input-status: up
output-interface: inside
output-status: up
Action: allow
And I found where the problem was. I fill like an idiot! The host where the translated IP address was configured - 10.1.6.10 was lacking a default gateway. It's actually a switch, and I have configured an SVI on it, just to test connectivity.
Now the translation works!
Only one thing bothers me a bit. When I ping from outside -> inside... the show nat outputs shows no translated matches:
1. Befor the ping, I have cleared the counters:
    translate_hits = 0, untranslate_hits = 0
2. Ping from outside (network 10.1.5.0/24) to inside:
BB1#ping 149.13.0.21 repeat 100
Sending 100, 100-byte ICMP Echos to 149.13.0.21, timeout is 2 seconds:
Success rate is 100 percent (100/100), round-trip min/avg/max = 1/2/4 ms
    translate_hits = 0, untranslate_hits = 100
3. Ping from inside to outside, with the NAT counters left as they are from 2.
Rack1ASA2-StatefulNAT-Test/NAT# show nat
    translate_hits = 5, untranslate_hits = 100
Is this something to worry about?
Karsten Iwen Tue, 08/19/2014 - 10:21
the failures that make you feel that are often the hardest to find ...
The ping from inside to outside were only five pings? Then the output is perfectly fine. untranslate_hits match inboound, translate-hits match outbound.
Boyan Sotirov Thu, 08/21/2014 - 01:35
 Thank you Karsten, now I've got it...
I've deliberately used different number of pings.
Boyan Sotirov Tue, 08/19/2014 - 05:04
The IP address that I'm translating to is reachable from the ASA:
Rack1ASA2/NAT# ping 10.1.6.10
Sending 5, 100-byte ICMP Echos to 10.1.6.10, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
Related Content
