Warning message
RSP720-3CXL-GE in Cisco 7613-S Chassis (Incompatibility)
Aug 18th, 2014
Hi everyone,
Does anyone know if the RSP720-3CXL-GE is compatible in Cisco 7613-S Chassis, maybe is an IOS issue or a bootstrap?
*Aug  7 20:31:18.839: %C7600_PLATFORM-1-DISABLE_NON_C7600_CHASSIS: Software has
detected an attempt to run a c7600 image on an incompatible chassis CISCO7613-S
(53249). This image will not boot.
Thanks in advance,
Overall Rating: 5 (1 ratings)
Leo Laohoo Mon, 08/18/2014 - 16:10
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
According to the data sheet:
Cisco 7604, 7606, 7606-S, 7609, 7609-S, and 7613
No mention is made about the 7613-S.
For the 7613-S, the only supervisor available is the Sup2T.
Overview
The supervisor engine or route switch processor (RSP) is a module that is installed in one of the card slots in the router. The supervisor engine or RSP provides switching and local and remote management for the router and also contains the uplink ports for the router. Both types of modules (supervisor engine and RSP) perform the same functions in the router.
Cisco 7600 series routers support the following types of RSPs and supervisor engines:
•Route Switch Processor 720—Supported on all chassis (including enhanced) except the Cisco 7603 router and the Cisco OSR-7609. Available in Cisco IOS Release 12.2SRB and later releases.
•RSP720-10GE (with 10GE uplink ports)—Supported on the Cisco 7604 and 7609 routers and the Cisco 7603-S, 7606-S, and 7609-S routers (enhanced chassis). Available in Cisco IOS Release 12.2SRC and later releases.
•Supervisor Engine 720—Supported on all Cisco 7600 series routers.
•Supervisor Engine 32—Supported on all but the Cisco 7603 router.
•Supervisor Engine 2—Supported on all but the Cisco 7613 router. The Supervisor Engine 2 is no longer supported in Cisco IOS Release 12.2SRA and later releases.
•Supervisor Engine 2T —Supported on Cisco 7609-S routers (effective with Cisco IOS Release 15.0(1)SY1), Cisco 7613-S and 7604 routers (effective with Cisco IOS Release 15.1(1)SY. )
Although the router can operate with a single supervisor engine or RSP, you can also install a second redundant module (of the same type) in the chassis. Only one module is active at a time. The second module acts as a "standby," serving as a backup if the active module fails.
David Mejia Tue, 08/19/2014 - 06:36
leolaohoo, thank for your answer,
But in the 7613-S Data sheet stays that it support the RSP720-3CXL, could be the IOS version, please if anyone knows which one will be the correct one?
http://www.cisco.com/c/en/us/products/collateral/routers/7600-series-rou...
Supervisor support: Cisco Route Switch Processor 720 (RSP720-3C andRSP720-3CXL)
Minimum software release
  Cisco IOS Software Release 15.3(1)S for Route Switch Processor 720  and Release 15.1(1)SY for the Supervisor 2T
Leo Laohoo Tue, 08/19/2014 - 07:07
  • Hall of Fame,
    2017 LAN, Wireless
Look at your supervisor card.  It only has 1 Gbps uplink.   This stuff I posted requires the RSP720 with 10 Gbps uplink.
It still won't work.
 Supervisor support: Cisco Route Switch Processor 720 (RSP720-3C andRSP720-3CXL) and the new Cisco Catalyst 6500 Series Supervisor Engine 2T (VS-S2T-10G and VS-S2T-10G-XL).
This is where you got the line.  But notice the Sup2T at the end?  They are 10 Gbps uplink.  So I believe only the RSP with 10 Gbps uplinks are allowed.
David Mejia Tue, 08/19/2014 - 12:31
Yep the supervisor only has a GE uplink, :(
Is it posible that maybe Cisco release any compatible IOS for 7613-S Chassis?
and Thank you so much for your help Leo Laohoo .
Rajeev Sharma Wed, 08/20/2014 - 12:57
  • Silver, 250 points or more
David,
I did find something for us however its very complex and needs exhaustive live troubeshooting so I suggest you to open a TAC case and get help over a webex session.
RS.
Rajeev Sharma Mon, 08/25/2014 - 19:14
David,
Did you open TAC case for this issue?
RS.
David Mejia Mon, 06/08/2015 - 14:34
Hi well.... we had to return the chassis..... the vendor give us a new one, so everything es working well.
Then the RSP720-3CXL-GE is compatible in Cisco 7613-S Chassis for shure
regards
DavidM
David Mejia Tue, 08/19/2014 - 14:01
I tried with these:
c7600rsp72043-adventerprisek9-mz.153-1.S.bin
c7600rsp72043-ipservices-mz.152-4.S4a.bin
c7600rsp72043-advipservicesk9-mz.122-33.SRE10.bin
and this is the console log
Thanks for your help
> > Self extracting the image... [OK]
> > Self decompressing the image :
> > ######## [OK]
> > Restricted Rights Legend
> > Use, duplication, or disclosure by the Government is
> > subject to restrictions as set forth in subparagraph
> > (c) of the Commercial Computer Software - Restricted
> > Rights clause at FAR sec. 52.227-19 and subparagraph
> > (c) (1) (ii) of the Rights in Technical Data and Computer
> > Software clause at DFARS sec. 252.227-7013.
> > cisco Systems, Inc.
> > 170 West Tasman Drive
> > San Jose, California 95134-1706
> > Cisco IOS Software, c7600rsp72043_sp Software
> > (c7600rsp72043_sp-ADVIPSERVICESK9-
> > M), Experimental Version 12.2(20100507:163556) [csethukk-srcengspltac 163]
> > This software is supported for a limited time under special agreement with
> > Cisco
> > Systems, Inc. Reference case CAP002278.
> > Copyright (c) 1986-2010 by Cisco Systems, Inc.
> > Compiled Thu 13-May-10 21:29 by csethukk
> > Image text-base: 0x080000B8, data-base: 0x0C000000
> > Buffered messages:
> > Queued messages:
> > *Aug 7 20:31:18.883: %SYS-3-LOGGER_FLUSHING: System pausing to ensure
> > console d
> > ebugging output.
> > *Aug 7 20:31:18.479: CM file
> > (ivfs:/c7600rsp72043_sp-advipservicesk9-m_matrix.c
> > m) is not readable, using internal matrix table
> > *Aug 7 20:31:18.739: %PFREDUN-6-ACTIVE: Initializing as ACTIVE processor
> > Software has
> > CISCO7613-S
> > *Aug 7 20:31:19.467: %SYS-3-LOGGER_FLUSHING: System pausing to ensure
> > console d
> > ebugging output.
> > *Aug 7 20:31:19.467: %SYS-3-LOGGER_FLUSHED: System was paused for
> > 00:00:00 to e
> > nsure console debugging output.
> > *Aug 7 20:31:19.467: %PFREDUN-4-SUP_FORCE_TO_ROMMON: Supervisor forced to
> > rommo
> > n with reason: Cannot continue... disabling autoboot and resetting
> > Resetting .......
> > System Bootstrap, Version 12.2(33r)SRD5, RELEASE SOFTWARE (fc1)
> > Technical Support: http://www.cisco.com/techsupport
> > Copyright (c) 2009 by cisco Systems, Inc.
> > C7600-RSP720/SP platform with 2097152 Kbytes of main memory
> > rommon 1 >
