Warning message
ISE Authentication issue when configuring both profiling and 802.1x
Aug 19th, 2014
Hi all
I have an issue when configuring profiling and 802.1X EAP-TLS at the same time. When configuring EAP-TLS only, users can authenticate using their certificates without any problem.
Once I enable profiling, the MAC address of the EAP-TLS client is recorded into the internal database of ISE, and then the client is authenticated through MAB.
Any idea to solve this issue ?
nspasov Thu, 08/21/2014 - 09:08
  • Cisco Employee,
  • Cisco Designated VIP,
    2017 AAA, Identity and NAC Security
You shoudl be able to accomplish this by changing the authentication priority/order on the switchport(s)
 authentication order dot1x mab
 authentication priority dot1x mab
Hope this helps!
Thank you for rating helpful posts!
