Warning message
Cisco SPA5252 IMAGE CRC Error
Aug 19th, 2014
When I try to update my Cisco SPA525G2 (currently on 7.5.5) to 7.5.6 I get the following error:
IMAGE CRC Error
I also tried upgrading by using the following url:
192.168.0.101/admin/upgrade?http://<ip>/cisco/firmware.bin
where the firmware file originally was named:
spa525g-7-5-6.bin
Another issue that is ocurring somtimes is after populating the attendant console, the phone performs a factory reset.
We are using the SPA525G2 as a stand-alone SIP phone, I tried to manage it using CCA, but I am unable to authenticate for whatever reason (cisco cisco, admin admin and other variations did not work)
How can I force an firmware upgrade, or is there something else wrong?
Dan Lukes Tue, 08/19/2014 - 13:41
  • Red, 2250 points or more
  • Cisco Designated VIP,
    2017 Small Business
Wrong forum. It has nothing to do with XML Phone Applications. Please delete it here and recreate in more appropriate forum: SPA IP Phones
In the meantime - download the file from http://<ip>/cisco/firmware.bin by self. Compare the file downloaded with original spa525g-7-5-6.bin. Are the same ? Check MD5 of the file - it should be
MD5 (spa525g-7-5-6.bin) = 860a2bdac1a9e6129e0612718069dfd5
What's current firmware of the phone in question ?
Note - as long as you consider to manage phone using CCA you can't manage it locally at the same time. So you can't login to management UI.
Related Content
