AIR-AP1242AG-a-K9
Aug 20th, 2014
OK I have a AIR-laP1242AG-a-K9 but I have now down graded it to a AIR-AP1242AG-a-K9. But the problem am having. Is when I login to the administration panel and edit anything and then click the apply button nothing happen and it dose not. Save to the AP so does anyone have any ideas in where am going wrong
Ravi Singh Wed, 08/20/2014 - 09:33
  • Cisco Employee,
May I know the reason why you down graded? Is other function of AP is workimg fine?
wildchid66 Wed, 08/20/2014 - 09:45
The reason why you down graded. Is am using. As a Ap in my Home and dont have a wireless controler And no not all things or working when I edit anything. And the try and apply the changes they don't apply to the AP. Its like the apply button don't work
Sandeep Choudhary Mon, 09/01/2014 - 02:23
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Wireless
I think you want to set AP as Repeater/Bridge.
There are porblems but not always with GUI. Its alwayas good to configure Autonomous AP via CLI this is the best way.
If you need the config guide, check this:
http://rscciew.wordpress.com/2014/05/24/single-ssid-configuration-on-aut...
http://rscciew.wordpress.com/2014/05/24/multiple-ssid-configurations-on-...
any more question then please write here.
Dont forget to rate helpful posts
wildchid66 Sun, 08/31/2014 - 09:56
right i have found out why it was not working it was the web interface i was using but now i have a new problem and this is what i get when i try and set it as a Repeater after i have use the Express Security page to create unique SSID as it says in the Configuration Guide and saved it i then try to set it as a Repeater and get
Message from webpage
ERROR:
'Set Infrastructure SSID' must be configured in order to set the 'Role in Radio Network' to the following roles:
- 'Repeater'
- 'Access Point(Fallback to Repeater)'
- 'Non-Root Bridge'
- 'Non-Root Bridge with Wireless Clients'
(See Security>SSID Manager page).
any help please
