Warning message
outgoing calls not working
Answered Question
Aug 21st, 2014
Dears,
any one can help me in the following outgoing calls not working for the config , incoming is working , but outgoing not working
we ordered the following, we installed the CME 8.0
CISCO2901-V/K9
Cisco 2901 Voice Bundle  PVDM3-16  UC License PAK  FL-CUBE10
FL-CME-SRST-5
Communication Manager Express or SRST - 5 seat license
VIC2-4FXO
Four-port Voice Interface Card - FXO (Universal)
ISM-SRE-300-K9
Internal Services Module (ISM) with Services Ready Engine
FL-CUE-MBX-5
Unity Express License - 5 Mailbox - CUCM and CUCME
Correct Answer by islam.kamal about 2 years 11 months ago
Hello
Try to use port 0/0/0 instead of 0/0/1 because your configuration is under port 0/0/0 and for sure you do not have any circuit connect to 0/0/1 as the below:-
dial-peer voice 1001 pots
 corlist outgoing localcalls
 description "Local Calls"
 preference 1
 destination-pattern 9[1-8][^0][^0]....
 port 0/0/0
 forward-digits 7
please rate all useful information
Correct Answer by Chintan Gajjar about 2 years 11 months ago
For the given number,
the dial-peer will match is:
 preference 1
 port 0/0/1
 forward-digits 7
 no sip-register
and it will match the port 0/0/1, but port 0/0/1 doesnt looks to be configured to me.
voice-port 0/0/1
can you configure the port, or try changing dial-peer to point to port 0/0/0
regards
Chintan
Overall Rating: 5 (2 ratings)
Chintan Gajjar Thu, 08/21/2014 - 05:21
  • Blue, 1500 points or more
please give some more information on what number you are dialing and from what number your are dialing?
regards
Chintan
Correct Answer
Chintan Gajjar Sun, 08/24/2014 - 13:14
 preference 1
 port 0/0/1
 forward-digits 7
 no sip-register
voice-port 0/0/1
regards
Chintan
Correct Answer
islam.kamal Sun, 08/24/2014 - 21:54
  • Red, 2250 points or more
Hello
 preference 1
 port 0/0/0
 forward-digits 7
