NAT configuration problem on cat6500
Aug 22nd, 2014
Hi expert
I have tried to configure nat for a subnet, and I can ping from external, but not get remote desktop work. my configure is below:
interface vlan 111
   ip address 10.1.1.1 255.255.255.0
   ip nat inside
   if flow ingress
   ip pim sparse-dense-mode
interface vlan 2
   ip address xxx.xxx.2.1 255.255.255.0
   ip nat outside
   ip flow ingress
ip nat pool NatPool xxx.xxx.2.24 xxx.xxx.2.31 prefix-length 29
ip nat inside source list NatSub pool NatPool overload
ip access-list extended NatSub
    permit ip 10.1.1.0 0.0.0.255 any
if I am in subnet 10.1.1.0/24 or other subent in cat6500, I can use remote desktop to acccess the machine by the private ip address,
but, if I am out to internet, and remote login using remote desktop connection by the public address, I can not get connection.
Could any one advice, what possible problem I may have?
Any comments will be appreciated
Thanks in advance
Julxu
Reza Sharifi Fri, 08/22/2014 - 09:22
  • Cisco Designated VIP,
    2017 LAN
You have the prefix-length as 29 but the mask on the interface is /24 ( ip address xxx.xxx.2.1 255.255.255.0)
Can you change the prefix-length to 24 and test again?
