How do you create a VDC against and AWS Compute POD?
Aug 22nd, 2014
Does anyone have any guidance on how to create a Virtual Data Center against an AWS based Compute POD? The problem that I have is after choosing my AWS based Compute POD, the VDC UI asks for the Amazon EC2 networks. However, the list is left unpopulated, so I can't submit the error because the EC2 network is required. I've registered the three "default" EC2 networks that were discovered for my region that are based on the availability groups, but they don't show up.
Thanks in advance,
Bill
teocekn68 Thu, 05/21/2015 - 02:14
Go ot AWS console,
create a VPC, then follow by create a subnet.
back to PSC, run a discovery. u will then see the discovered subnet. register that object, and u should be able to use it to: Service Portal->Setup->system settings->networks->add a network , select network type="user"
Related Content
