Warning message
unable to power up MPA A9K-MPA-8X10GE state:FAILED
Hi Guys, need your advice. We have installed the MPA A9K-MPA-8X10GE to the line card and try multiple commands but failed to bring that up. However if we we reset the line card and it works. We understand as per spec this card is supporting OIR. The question is there any special command that can initialise the card and make it work without reseting the linecard We are not able to reset the LC because it is life machine. LC/0/1/CPU0:Aug 21 20:04:46.656 AEST: pcie-server[77]: addup_resources: Alloc mem failed LC/0/1/CPU0:Aug 21 20:04:46.656 AEST: pcie-server[77]: addup_resources: Alloc mem failed LC/0/1/CPU0:Aug 21 20:04:56.659 AEST: pcie-server[77]: addup_resources: Alloc mem failed LC/0/1/CPU0:Aug 21 20:04:56.660 AEST: pcie-server[77]: addup_resources: Alloc mem failed LC/0/1/CPU0:Aug 21 20:04:56.660 AEST: lda_server[65]: %PLATFORM-LDA-3-MPA_POWER_FAILURE : Unable to power on MPA in bay:1. Reason:PCIE init failed (0x00000013-No such device) LC/0/1/CPU0:Aug 21 20:04:57.466 AEST: lda_server[65]: %L2-SPA-5-OIR_ERROR : timeout when waiting for hw signal for SPA in bay 1 LC/0/1/CPU0:Aug 21 20:04:57.466 AEST: lda_server[65]: %L2-SPA-5-STATE_CHANGE : SPA in bay 1 type A9K-MPA-8x10GE Initing RP/0/RSP0/CPU0:Aug 21 20:04:57.469 AEST: invmgr[257]: %PLATFORM-INV-6-NODE_STATE_CHANGE : Node: 0/1/1, state: FAILED RP/0/RSP0/CPU0:Aug 21 20:04:57.473 AEST: shelfmgr[381]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/1/1 A9K-MPA-8X10GE state:IN-RESET
smilstea Sat, 09/13/2014 - 10:29
  • Cisco Employee,
Have you seen this multiple times?
Can you do OIRs without issue now?
Do you have a TAC SR opened?
Sam
