Warning message
Help on Site-to-Site IPsec VPN
Aug 25th, 2014
I would like to create a site-to-site IPSec VPN on Cisco 1941 router.
1. What license do i need for the routers (k9 or sec/k9)?
2. Do I need static public IP addresses for all of the sites?
3. Is there a limit on the number of sites?
Thanks in advance for your help.
michael o'nan Mon, 08/25/2014 - 19:41
  • Silver, 250 points or more
You will need sec/k9 for VPN. It could be easier with static addresses or at least one site as static. Others can be dynamic and you will be required to use a dynamic crypto map. You will be limited to your hardware (not sure of the number) but you could look into DMVPN and see if that would be a better fit for your needs.
nkarthikeyan Tue, 08/26/2014 - 04:12
  • Gold, 750 points or more
Please find the answers for your queries.
Ans: You need to update with Security Technology Package License (SL-19-SEC-K9(=) / L-SL-19-SEC-K9= )
Ans: You have options... If you have hub site and all other spoke sites connecting to it... you can have a static address at your hub site and other sites you can have dynamic ip address for peer.
Ans: Yes, there should be some limit on the VPN peers.
Karthik
