Warning message
Cisco 7800 series ip phones
Endorsed Question
Aug 25th, 2014
Hi All
cisco 7821 is configured with 8 speed dials however when you hit the down button it wil lonely show the first 6 ?
anyone have a resolution ?
You can still  dial the 7/8th speed dials but you cannot view them with the button (pressing down on the main button)  , pressing down gives you your speed dials (only 6) , pressing up gives you dial history (no limit)  ?
Cheers
Henry
Cisco Endorsed by Anil Rajan - Cisco Endorsed by harpsoni
Murali Gunnam about 2 years 11 months ago
If you would like to have more, you may configure Abbreviated Dialing which will give the option to use 99 index codes on the phone keypad.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/7821_7841_7861...
Murali
Overall Rating: 5 (2 ratings)
Manish Gogna Tue, 08/26/2014 - 00:11
  • Cisco Employee,
Hi Henry,
I am able to recreate this in my lab setup and do not see any setting which allows this number to be increased beyond six speed dials, it most definitely looks like working as designed.
Manish
