Warning message
michael o'nan Wed, 08/27/2014 - 09:18
  • Silver, 250 points or more
I suppose you could set up port forwarding or something similar. I would suggest looking into Collaboration Edge as it will be the most secure.
Hythim Ali El Hadad Wed, 08/27/2014 - 09:23
I'm in a new project
How to get the expressway edge and expressway core software with the initial license ?
michael o'nan Wed, 08/27/2014 - 09:34
If you need the software and license you should contact your Cisco Partner or Cisco SE. They will be able to direct you on how to order and download.
