Warning message
dhcp binding shows same device twice
Endorsed Question
Aug 28th, 2014
I am trying to assign a static IP to a radar on my network. The mac address is 0100.08de.0000.00
I have the following in the running config:
ip dhcp pool radar
host 10.1.30.176 255.255.255.0
hardware-address 0100.08de.0000.00
when i enter show ip dhcp binding
the mac address shows up twice on the list
10.1.30.106  0100.08de.0000.00   aug 29 2014  automatic
10.1.30.176  0100.08de.0000.00  infinite         Manual
It appears the radar is receiving a dhcp lease rather than the static address I want it to take. I can ping the radar on 10.1.30.106 not 10.1.30.176.
Why won't the radar accept the  .176 ip?
Cisco Endorsed by educruz
Sandeep Sharma about 2 years 11 months ago
The best way is to first use exclude command and then try client identifier. You can use the steps below:
ip dhcp excluded-address <ip address you are trying to get rid of the lease from>
then instead of hardware-address, try using client-identifier
ip dhcp pool STATIC
  host 10.1.130.176 /24
  Client-identifier xxxx.xxxx.xxxx
Do ipconfig /release then ipconfig /renew in command prompt and it will bind the IP to the computer's mac address. you can later do  "no ip dhcp excluded-address" to make sure the IP add held to the computer.
Or you can also try directly these commands:
ip dhcp pool STATIC
Thanks & Regards
Sandeep
Overall Rating: 5 (1 ratings)
Walter Astori Fri, 08/29/2014 - 02:52
Can you try to use client-identifier and remove the command hardware-address ?
Sandeep Sharma Fri, 08/29/2014 - 04:03
  • Cisco Employee,
ip dhcp pool STATIC
ip dhcp pool STATIC
Thanks & Regards
Sandeep
