Warning message
configuration of pppoe over gigabitethernet with ASR 901 and OS 15.4(3)S
Sep 1st, 2014
I am currently trying to configure my ASR 901 router with 15.4(3) OS version to use  the PPPoE over one of the Gigabithernet port, but I'm facing some issues because in every tutorial I have seen, they specify to perform the "pppoe enable global" command on gigabitethernet interface but with my version, I can't find the pppoe command.
So, is there any other command or configuration to set the pppoe over gigabit ethernet or something or is there something I'm missing.
Below the configuration found:
Server(config)#<strong>bba-group pppoe global</strong>
Server(config-bba-group)#<strong>virtual-template 1</strong>
Server(config)#<strong>interface virtual-template 1</strong>
Server(config-if)#<strong>ip address 192.168.12.2 255.255.255.0</strong>
Server(config-if)#<strong>mtu 1492</strong>
Server(config-if)#<strong>peer default ip address pool CLIENT</strong>
Server(config)#<strong>ip local pool CLIENT 192.168.12.1</strong>
Thanks a lot
rizwanr74 Wed, 09/03/2014 - 06:35
  • Gold, 750 points or more
Hi tamsir901,
Please remove what you have and configure what is posted below.
You need to make sure with your provider whether they use "chap" or "ptp", as shown in the highlighted in the "ppp authentication chap callin" authentication protocol.
interface GigabitEthernet0/0
 no ip address
 duplex auto
 speed auto
 pppoe enable group global
 pppoe-client dial-pool-number 1
interface Dialer1
 ip address negotiated
 ip mtu 1492
 ip nat outside
 ip virtual-reassembly
 encapsulation ppp
 dialer pool 1
 ppp chap hostname [email protected]
 ppp chap password yourDSL-Password
interface GigabitEthernet0/1
 ip tcp adjust-mss 1452
ip route 0.0.0.0 0.0.0.0 Dialer1
I assume your inside lan interface is "GigabitEthernet0/1" and outside interface is "GigabitEthernet0/0"
Hope this helps.
Rizwan Rafeek
