Warning message
Remote Access VPN users unable to communicate with each other
Sep 1st, 2014
We have configured Remote Access VPN on Cisco IOS router. Users are able to access the inside resources but cant communicate to each other. Any suggestions on the issue?
Saif
Marius Gunnerud Mon, 09/01/2014 - 03:05
  • Red, 2250 points or more
  • Cisco Designated VIP,
    2017 Firewalling
What type of RA VPN have you set up? (AnyConnect, IPsec VPN, Easy VPN)
Please remember to select a correct answer and rate helpful posts
Richard Burts Mon, 09/01/2014 - 17:14
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Try adding this to the config and see if the behavior changes
same-security-traffic permit intra-interface
and you might also try its companion command
same-security-traffic permit inter-interface
Rick
Richard Burts Tue, 09/02/2014 - 04:16
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
I obviously did not read the original post carefully enough. Thank you for pointing out the difference in platform.
Rick
Walter Astori Tue, 09/02/2014 - 05:52
You must insert the inside host in the access-list crypto and in the access-list nonat (nat(INSIDE) 0)
Marius Gunnerud Tue, 09/02/2014 - 06:08
    2017 Firewalling
I have already mentioned this in one of my posts, and NAT 0 is an ASA function we are talking IOS here (ie. routers)
Marius Gunnerud Tue, 09/02/2014 - 02:39
    2017 Firewalling
Have you excluded the VPN traffic from being NATed when traffic is going between clients?
Please post a full sanitised configuration of the router so we can check it for configuration issues.
