Warning message
Unity Connection 7.1.5b or 8.0(3a) installation failing
Answered Question
Sep 1st, 2014
Hi everyone,
I am trying to install Unity Connection 7.1.5b or 8.0(3a) as a first step before upgrade to 10.5; I am using UCS C220 M3 SFF, VMWare Sphere ESXi 5.5, using OVA from Cisco, but I am getting the following errors each time:
Has anyone has fixed this error before?
Be great to get some advice.
Cheers
Correct Answer by Carlo Poggiarelli about 2 years 11 months ago
Hi Alberto.
Which template did you downloaded?
Check the network adapter configured on VM ad if E1000 , change it to Felx.
This caused me a similar issue while installed cucm 8.5
Carlo
Overall Rating: 5 (1 ratings)
Aman Soi Tue, 09/02/2014 - 05:48
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 IP Telephony
I have never faced this issue.But the attached snapshot points to Ethernet auto-negotiation issue.
Did u check the settings on switch?
regds,
aman
Correct Answer
Carlo Poggiarelli Tue, 09/02/2014 - 06:32
  • Green, 3000 points or more
Hi Alberto.
Carlo
alberto-vazquez Wed, 09/03/2014 - 09:21
Hi!
Problem solved, I changed the network adapter type from VMXNET3 to E1000 just like Carlo recommended.
I was able to install CUC 7.1(5b) in VM
cheers
