09-01-2014 10:41 PM - edited 03-21-2019 08:22 AM
Hello everyone!
I'm creating software for control spa phone: make calls, control calls, viewing incoming, outgoing and etc.
One problem, what I'm solution not found is: how get current ringing lines via http request?
Maybe exist a method like CGI/Execute (ciscoipphoneexecute) via http request to get current line status (ringing, idle, connected, cancel) and phone caller?
I trying using file http://ipphone/status.xml but download them is too slow (1-1,2 sec.). Exist over and right way?
Thx.
09-08-2014 08:53 PM
I tried some software recently called SPA Call Manager Pro. It requires SIP debug set to "full" on the Ext 1 tab as well as debug server set and debug level set to 3 (uses syslog protocol with default port).
Maybe that sort of approach is the only way you can catch enough state information from the phone to do what you are wanting - you could constantly parse this data to determine the ringing call state, and that way you get instant information without a delay.
An alternative approach is to do it on the asterisk side by using the Asterisk Manager or HTTP-based ARI.
09-08-2014 11:44 PM
You may be interested to read Call Ctrl - Click to Dial & Call Manager
Note that software is no longer sold (as far as I know).
