Warning message
2960 pb with Alcatel ip phone
Sep 2nd, 2014
Hi i have 2 issue with Alcaltel IP phone an 2960 switch
1) 2960X WS-C2960X-24PS-L
 all our switch are configured with the following
interface GigabitEthernet1/0/1
switchport access vlan dynamic
switchport mode access
switchport nonegotiate
switchport voice vlan 29
srr-queue bandwidth share 1 30 35 5
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
spanning-tree portfast
to make it work with the 2960x release c2960x-universalk9-mz.150-2.EX5.bin or 150-2.EX3
we need to configure
interface GigabitEthernet1/0/42
switchport access vlan 18
switchport trunk native vlan 18
switchport trunk allowed vlan 18,29
priority-queue out
mls qos trust cos
auto qos trust
to make it to work
we don't use switchport access vlan dynamic
2)WS-C2960S-48lPD-l version c2960s-universalk9-mz.152-1.E2 the issue is also in other versions
after use off 802.x who works fine and reconfigure to default off the interface  the voice vlan don't work
the shut down off the ip phone doesn't resolve the issu
the only way is to reload the 2960x
Note : le problème persiste quelque soit la méthode utilisée pour retirer l'authentification :
 - (config-if)#no authentication ...
 - (config-if)#default authentication ...
 - (config)#default interface GigabitEthernet1/0/3
dot1x system-auth-control
 description test
 switchport access vlan 14
 switchport voice vlan 20
 authentication event fail action authorize vlan 85
 authentication event no-response action authorize vlan 85
 authentication host-mode multi-domain
 authentication port-control auto
 authentication violation protect
 mab eap
 dot1x pae authenticator
 dot1x timeout tx-period 4
has someone the same issues and has someone the solution?
