Routing
Labels
Hello,I have topology like this picture where we have 2 WAN connection to bridge LAN1 and LAN2. We use OSFP for the routing and we have NPM (from solarwinds) to monitor WAN connection from LAN1.In the NPM i create 2 node with ip 10.100.1.2 and 10.101...
hs08 by Spotlight
  • 35 Views
  • 0 replies
Hello Cisco Community.I hope I could make myself clear, cause my homelanguage isn' t english.I have SG350-28P and two internet connection, witch connected with Mikrotik router, witch doing NAT.My goal:Mikrotik 1 - let' s say vlan10 and 192.168.0.1/24...
Can someone explain what this configuration is doing, at a high-level, I am just trying to understand what is going on here?  The route-map statements 20, 30, and 40 really don't do anything, correct? CPE-1 Configurationrouter bgp 2152neighbor casc-d...
eagleeye by Level 1
  • 154 Views
  • 4 replies
Bonjour,J'ai un VLAN bureautique en 192.168.1.0. Mon CBS350-8T-E-2G a l'adresse 192.168.1.240.La passerelle par défaut est le 192.168.1.1.J'ai un VLAN formation en 192.168.80.0. Mon CBS350-8T-E-2G a l'adresse 192.168.80.1, le dhcp fonctionne parfaite...
Hello all!A small disclamer here, i am completely new to the cisco environment. And therefore this is my first ever configuration to a cisco router. The router is a ISR-1100 series.I have tried following the start guides and basic configuration, but ...
Hevos93 by Level 1
  • 67 Views
  • 0 replies
Hi, we have one lease line with bandwidth 500Mbps, the current max transmit is 70Mbps. we have configured traffic shaping on the outgoing interface, and set CIR to 500Mbps. After applied QoS, still see the packet drop. The router interface is 1Gbps.C...
Resolved! BGP and Loopback
 Hello,I was able to reach ank_linux computer from ist_linux computer, I created loop back interface on both routers, now I can't reach ank_linux computer from ist_linux computerany suggestions?
CISCOLOG by Level 1
  • 247 Views
  • 5 replies
Hi Guys,I have 2 pairs of Nexus switches, each pair at each location. They connect between 2 locations with 2 x layer 3 links, as shown in the diagram.I configured EIGRP routing for both sites for these 2 pairs. The EIGRP routing works; my question i...
HiI'm facing some issue while useing ASA in gns3.....i have already attach the gns topology in which i'm not able to get the console of asa also i have attached the snapshoot in which u can see BOOTING THE KERNEL but in other window of asa console cl...
