Warning message
Use of straight through and cross over cable
Endorsed Question
Sep 4th, 2014
hi,
according to icnd1, we need to use crossover cable to connect similar devices, lets say router to router or switch to swicth..
does this really matter? I mean, what if i use straight through cable to connect one switch to another?
thanks
Cisco Endorsed by juspierc
gmicek about 2 years 11 months ago
Also, note that switches and hubs are both MDI-X devices while routers and PCs are MDI devices. You have to use a crossover cable when using MDI together or MDI-X together, but you would use a straight-through cable when connecting MDI to MDI-X and vice versa.
Thus, a router and a router would use a crossover cable to connect, a router and a switch would use a straight-through cable, but a router and a PC would use a crossover cable.
Again, in practical use most devices nowadays use auto-MDI, so it usually doesn't matter.
Cisco Endorsed by Virnell Jones
Sajith Joseph about 2 years 11 months ago
Hi Vishal,
A switch is an MDI-X device. That means the pin arrangement is as follows:
Pin#  Function
1       Receiver+
2       Receiver-
3       Transmitter+
6       Transmitter-
So if you want to connect another switch to this switch, you have to make sure the Transmitter pins are connected to Receiver pins and vice versa. If you use a straight thru cable, Receiver pins will be connected to Receiver pins on the other end and same for transmitter pins and this will not work for sending or receiving data. Therefore you need to use a crossover cable. Remember in crossover: 1->3 ; 2 -> 6 ; 3 -> 1 ; 6 -> 2
Hope that helps
Sajith
Overall Rating: 5 (2 ratings)
michael o'nan Thu, 09/04/2014 - 10:57
  • Silver, 250 points or more
For the test, yes. For real life device now use auto MDIX and can detect the cable and correct the pinout.
vishalpatil86 Wed, 10/15/2014 - 07:10
I want to extend this discussion a little bit. If only two pairs are used in receiving and transmitting.
What are other two pairs for?
rajeshroshan02 Fri, 10/17/2014 - 20:35
Hi Vishal,
The cable Pinouts depends on type of cable and ethernet speed.
In Cat5 cables supports 10BaseT, 100BaseT, we use on two pairs for Rx and TX.
But CAT5 E and CAT6 supports 1000 baseT, we use all 4 pairs for bi derection transmission.
PinNameDescription
1BI_DA+Bi-directional pair A +
2BI_DA-Bi-directional pair A -
3BI_DB+Bi-directional pair B +
4BI_DC+Bi-directional pair C +
5BI_DC-Bi-directional pair C -
6BI_DB-Bi-directional pair B -
7BI_DD+Bi-directional pair D +
8BI_DD-Bi-directional pair D -
Joseph W. Doherty Mon, 09/08/2014 - 05:46
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Hmm, I don't know, does it really matter whether the link between devices can be used?  (Laugh)
As the other posters have noted, many (newer) devices now support auto MDI/MDIX, but some don't.  (Also, on devices that do, auto negotiation might be required to be enabled.)  Some older devices sometimes have "special" uplink ports or manual method to switch the port's MDI/MDIX setting, and for those, too, you can use a strait through cable.
If none of the above, however, you'll need a cross over cable for "similar" device types, i.e. those whose tx/rx pins, on the port, are the same.
You need a cross over cable if both sides are MDI or MDIX (i.e. the same), straight cable if both sides are different.
Sajith Joseph Mon, 09/08/2014 - 07:35
Hi Vishal,
Pin#  Function
1       Receiver+
2       Receiver-
3       Transmitter+
6       Transmitter-
Hope that helps
Sajith
gmicek Wed, 09/10/2014 - 06:49
