09-06-2014 09:35 AM - edited 03-11-2019 09:43 PM
I got stuck setting up dynamic PAT on a 5525-X, IOS 9.1.
The setup is as following:
- the ASA is supposed to route a /28 over a /29 linknet
- g0/0 is the outside interface, connecting to provider core
- ASA uses last address on /29 (provider uses static route to route /28 to said adress)
- static route 0.0.0.0/0.0.0.0 on ASA points everything at the first address of the linknet (.17), hosted on the provider's SVI
- g0/1 uses a number of subinterfaces, to (eventually) route the /28 (to be configured on 0/1.100) and PAT a number of RFC1918 networks to grant them Internet access *via* unused addresses on the /29 (.19, in this case)
I have set up subinterfaces as seen in config below, but can't get out to the Internet on VLAN 200. The downstream switch has VLAN 200 trunked to it correctly and I can ping VLAN 200 gateway successfully (10.196.0.1). The ASA's default route also seems ok, as I can ping 8.8.8.8 from the ASA CLI.
Any tips greatly appreciated, as I run out of ideas..
ciscoasa(config)# sh run
: Saved
ASA Version 9.1(2)
hostname ciscoasa
enable password xxxxxxxxxx encrypted
names
interface GigabitEthernet0/0
nameif outside
security-level 0
ip address 111.222.333.22 255.255.255.248
interface GigabitEthernet0/1
nameif inside
security-level 100
no ip address
interface GigabitEthernet0/1.90
vlan 90
nameif device_management
security-level 0
ip address 10.192.0.1 255.255.255.0
interface GigabitEthernet0/1.100
vlan 100
nameif main
security-level 0
no ip address
interface GigabitEthernet0/1.110
vlan 110
nameif vpn
security-level 0
ip address 10.194.0.1 255.255.254.0
interface GigabitEthernet0/1.120
vlan 120
nameif rfc1
security-level 0
ip address 10.194.2.1 255.255.254.0
interface GigabitEthernet0/1.130
vlan 130
nameif rfc2
security-level 0
ip address 10.194.4.1 255.255.254.0
interface GigabitEthernet0/1.200
vlan 200
nameif student
security-level 0
ip address 10.196.0.1 255.255.252.0
interface GigabitEthernet0/1.210
vlan 210
nameif guest
security-level 0
ip address 10.196.4.1 255.255.252.0
interface GigabitEthernet0/2
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/3
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/4
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/5
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/6
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/7
shutdown
no nameif
no security-level
no ip address
interface Management0/0
management-only
nameif management
security-level 100
boot system disk0:/asa912-smp-k8.bin
ftp mode passive
object network services_public
host 111.222.333.21
object network guest_private
subnet 10.196.4.0 255.255.252.0
object network management_private
subnet 10.192.0.0 255.255.255.0
object network student_public
host 111.222.333.19
object network student_private
subnet 10.196.0.0 255.255.252.0
pager lines 24
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu device_management 1500
mtu main 1500
mtu vpn 1500
mtu rfc1 1500
mtu rfc2 1500
mtu student 1500
mtu guest 1500
mtu management 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-713.bin
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
nat (student,outside) source dynamic student_private student_public
route outside 0.0.0.0 0.0.0.0 111.222.333.17 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
http server enable
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpool policy
telnet timeout 5
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
dhcpd dns 111.222.1.1 111.222.1.2
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ssl encryption rc4-sha1 aes128-sha1 aes256-sha1 3des-sha1
username admin password EoGC0ChIqyj0NIb5 encrypted
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:9406632d0fab8fd1d99fe845393e7641
: end
ciscoasa(config)#
I tried to PAT student_private onto the outside interface (.22), but also without luck:/
Any tips much appreciated!
R.
Solved! Go to Solution.
09-06-2014 12:37 PM
Most of your internal networks have a security-level of 0. So by default you can't communicate to outside which also has a security-level of 0.
As these are all internal networks, I would give them quite high security-levels. 100 if they are equally to inside, 90 or so if they are not of same security-level as inside.
If you end up to still have more then one interface with the same security-level, you'll need to configure the command
same-security-traffic permit inter-interface
09-06-2014 12:37 PM
09-08-2014 05:34 AM
Many thanks for the tip, Karsten - correcting security levels has done the job!
Best wishes,
R.
