Warning message
seamless migration of cryptomap ipsec setup to vrf aware environment?
Sep 7th, 2014
hi out there
We are in a migration phase from a vpn router with a non-vrf aware setup to a router with a vrf aware setup. I expected that I was able to do this more or less seamless by adding the wan-interface from the vrf ware router to the same hsrp Group as the non-vrf aware router and the just raise the priority of the vrf aware router when we had a time slot for migrating the environment. But when I added the interface for the vrf aware router to the hsrp Group of the non-vrf aware router  the vrf-aware router suddenly started to "mal-function" - it had two other interfaces running with vpn connections and those sessions started to crash.
Since this is a production env I hadn't time to debug what happened but I just quickly rolled-back what I had done and everything looked ok and stable Again. But - can some here give me a guess of what had happened?
the setup I had on the non-vrf aware router was this:
interface GigabitEthernet0/0/0
ip address 19.41.10.13 255.255.255.128
standby 68 ip 19.41.10.14
 standby 68 priority 110
 standby 68 preempt
 standby 68 authentication xxxx
 standby 68 name asp
crypto map cm-cvn001 redundancy asp
and on the vrf aware env:
interface GigabitEthernet0/0/3
ip address 19.41.10.28 255.255.255.128
 vrf forwarding INTERNET3
 standby 68 priority 50
 standby 68 preempt
 standby 68 name asp
crypto map IPSECMAP3 redundancy asp
