Warning message
Unity Connection Upgrade 7.1.3 to 8.0 Fails
Sep 8th, 2014
We have Unity Connection 7.1.3 on UCS & we are upgrading to 8.0. Our target upgrade version is 10.5.
While upgrade we are getting following error.
Error encountered : errors. upgrade.connectionHWDisallowd.
We have used CUC OVA file to build CUC 7.1.3.  before upgrade to 8.0 we loaded cop file (ciscocm.referesh_upgrade_v1.3.cop.sgn)
Can any body advise why we are facing this issue ? We have UCS C200 M3 Server.
conie saga Mon, 09/08/2014 - 03:03
Hi aman,
Thank you for reply.
We downloaded files from Cisco Unity Connection Virtualization tab in Cisco.com under download section. We used CUC_5000_user_v1.0vmv7.ova file.
We just tried upgrade from 7.1.3 to 10.0.112900-2 & it upgraded successfuly.
Now on the way to 10.5.1.10000-7. I will udpate here with result today.
Aman Soi Mon, 09/08/2014 - 03:06
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 IP Telephony
thanks for update.
I was asking about the cop file.
So, finally u upgaded from 7.1.3 to 10.0.x.Did not upgrade to 8 and then, 10.X?
regds,
aman
Aman Soi Mon, 09/08/2014 - 03:43
    2017 IP Telephony
Can u also please share show version active and show version inactive ?
regds,
aman
conie saga Tue, 09/09/2014 - 05:50
Hi aman,
As requested, following is the ouptut
admin:show version active
Active Master Version: 10.5.1.10000-7
Active Version Installed Software Options:
ciscocm.refresh_upgrade_v1.3.cop
ciscocm.version3-keys.cop
admin:
admin:show version inactive
Inactive Master Version: 10.0.1.12900-2
Inactive Version Installed Software Options:
admin:
Conie
Aman Soi Tue, 09/09/2014 - 10:17
    2017 IP Telephony
thanks for update.
regds,
aman
conie saga Mon, 09/08/2014 - 12:12
Hi aman, Cop file i downloaded from callmanager 10.5 update utilities page at cisco.com and it is latest version of cop file. Yes, upgrde from ver 7.1.3 to 8.0 didnt went successful so alternate 7.1.3 to 10.0 and thn 10.5 successfull. I will share requested output here by tomorrow. Regards
